I have this problem that I can´t fixe yet...
I have a menu that call several pages by using ajax.
When I select a menu, it only load a php file with the code into a main <div> that I put in index file.
I have some form and the problem is that, when I call the file from my ajax function, in the form only load a textarea field, and do not draw de CKEditor options.
With the same code I have now, the FKEditor works fine, I just have to call de field using this:
But in the new CKEditor 3.2.1 when I put this:
It only load a textarea. If I call the file directly from the URL browser it works, but by Ajax no.
I think there is a problem when it try set the properties to textarea by Javascript...
Any one can help me... I'm work arround this several time, and I can´t figure out a solution...
Mogadix
$oFCKeditor = new FCKeditor($field) ; $oFCKeditor->BasePath = $sBasePath ; if ( isset($_GET['Skin']) ) $oFCKeditor->Config['SkinPath'] = $sBasePath . 'editor/skins/office2003/' ; $oFCKeditor->Value = $result["texto"]; $oFCKeditor->Create();
include_once "../../../ckeditor/ckeditor.php";
$initialValue = '<p>This is some <strong>sample text</strong>.</p>';
$CKEditor = new CKEditor();
$CKEditor->basePath = '../../../ckeditor/';
$CKEditor->editor("editor1", $initialValue);It only load a textarea. If I call the file directly from the URL browser it works, but by Ajax no.
Mogadix
Re: Problem Load CKEditor from a file call by AJAX
Had you fix the program yet?I can't draw de CKEditor options too with using ajax.If you had fix the problem,can you tell me how to fix the problem.Thanks very much!
I am loading up a form into a dialog using jQuery.load() and attempting to make the textareas on the form into CKEditor instances.
I've tried it both using replace:
$editDialog.load(str, null, function() { $("textarea", $editDialog).each(function() { CKEDITOR.replace(this.name); }); ...And the jQuery adapter, in two ways:
$editDialog.load(str, null, function() { $("textarea", $editDialog).each(function() { $(this).ckeditor(); }); ...and
$editDialog.load(str, null, function() { $("textarea", $editDialog).ckeditor(); ...None of these works. Furthermore, if I run any of these is freezes up the rest of the Javascript. No errors are thrown.
Any thoughts?
Tom
I got the editor to fully display by putting all the files - lang, etc at the root level. Even though the BasePath was set correctly.
But this is very messy.
With this implementation though, the posted value of the form is empty.
Any other ideas?
