Usign the version 6.0 of IE and the CKEditor 3.0, the Editor is not displayed and the error is 'lang.about.title' is null or is not and object.
Any of you have had a similar problem with this version of IE?
Thanks in advance,
Torres
Thanks in advance,
Torres
Re: Problem with I.E 6
if the demo page fails for you then you have something broken with your IE (and it wouldn't be a bad idea to upgrade it, you're using an 8 years old browser)
For me I use FF as web browser, but this aplication is for the administration so It have to work with all browers.
Thanks in advance,
Un saludo!
And of course, using the JS debugger of IE8 will be much easier than trying to use IE6
The problem was about relative paths that ckeditor.js construct to find the other config.js, etc. I have changed the relative path to an absolute path in the declaration of ckeditor.js and now everything works fine.
i ran into the same problem.
Don't know if that will be useful but here's what i did:
I'm using struts
my jsp was under a root like this"/WebContent/rep/myjsp.jsp"
the ckeditor "/WebContent/scripts/ckeditor/..."
So the link in my jsp was src="../scripts/ckeditor/..."
No matter what i did i got the error. Writing the absolute paht is out of the question.
The only solution i found is to move my jsp to the root of my WebContent repository
so i had :
/WebContent/myjsp.jsp
wich give me the link src="scripts/ckeditor/..." in my jsp.
Each time i tried with a relative path, the error occured.
Bye
<script type="text/javascript">CKEDITOR.replace( 'sidebar' , {customConfig : '/blog/custom/ckeditor_config.js'}); </script>
/blog is a subdirector of the root of the site, but nothing above this directory is calling the editor i.e. only called from /blog or deeper.
Regards
Pete
