Is there some where to strip out empty paragraphs and trailing spaces from the body field?
eg:
<p>
</p>
<p>
</p>
I'm using the editor, and want to use JavaScript to test for this in the front end rather than write server-side code to test for it.
I could replace it in JS, but cannot find a callout event for editor cleanup, etc.
eg:
<p>
</p>
<p>
</p>
Re: Pre-validating (javascript) for empty body?
http://cksource.com/forums/viewtopic.php?f=11&t=16915&p=43473&hilit=%26nbsp;#p43473
docs
You say the is created by the browser.. Every browser I have tried does the same thing.. 2 spaces.. and I get the inclusion of a character as the second space.. For a user/client to be told.. Oh yes.. remember to not put 2 spaces in between your words or you'll outputted HTML will have weird characters inbetween them.. not sure if this is advisable myslef and do not seem to get the same issue with TINY MCE? so is there a work around or not?
This seemingly small snag is stopping me from changing all my sites over to CKEDITOR! I was looking at the entities process_numerical.. but wasn't sure how to present this within a jquery function for configuration data! and also not sure if it's right as the process_numerical is talking about all those charaters not listed in the ASCII list.. and nbsp is? so would not be converted I guesss. anybody?
