The page up button does not work properly in the CKEditor. The page down button works properly. But if I press the page up button to go back up to the top, the cursor seems to reach the top (this is because if I press the down button it is already at the top) but the editor does not show the top where the cursor is. It is after I press the down button or tab away from the window and back that the editor refreshes itself.
The problem can be replicated on the demo page by the following steps:
1) Enter more lines at the end such that paging can be done.
2) Page down all the way.
3) Page up all the way. (Notice that the editor does not show the top when the cursor reaches the top).
Environment:
Internet Explorer 7 on Windows XP
Environment:
Re: Page up button in CKEditor does not work properly
Could you tell me what version of CKEditor are you using (perhaps some sort of integration)?
Are you using some special settings for CKEditor or are you are able to reproduce it in sample pages with default configuration?
I'm using the version of CKEditor that is shown on the demo page. it should be 3.6.1.
There isn't any special setting in Internet Explorer set.
Here is what I did:
1) I have copied the text from the demo multiple times.
2) I have placed the cursor at the top (next to ^Little Red Riding Hood)
3) I have paged down (two 'page downs' did the trick)
4) I have paged up (also two 'page ups' did the trick) - the cursor was next to ^Little Red Riding Hood.
If you could tell me what have I missed in my TC? Perhaps provide me with detailed steps how to reproduce the problem?
https://dev.ckeditor.com/ticket/7429
