I am working with a template which calls the old FCKEditor using the following:
I am trying to update the template to use the latest version of CKEditor. I have uploaded the necessary files and followed the installation instructions. Using the following I am able to get the editor to appear in the template along with the previously entered data (it is being used with a CMS).
However I cannot get the data to save. Looks like I need to create a javascript call that enables the data to be saved in a similar way as it was in the original but I have no idea how to do this with the CKEditor. Any help you can offer would be very appreciated. Thanks.
<textarea style="display:none" id="fck_source_{NAME}">{VALUE}</textarea>
function saveContent{NAME}(){
var oFCKeditor = new FCKeditor(
'{NAME}' ,
'{WIDTH}' ,
'{HEIGHT}' ,
'{TOOLBAR}' ,
document.getElementById("fck_source_{NAME}").value
oFCKeditor.BasePath = "3rdparty/fck/" ;
oFCKeditor.portId = '{NAME}';
oFCKeditor.Create() ;
CKEDITOR.replace( 'fck_source_{NAME}' );
Re: Moving from FCKEditor to CKEditor - help with save funct
That is if I'm understanding what you're wanting to do, correctly. Hope that gave you some help!
