Maximizer
i gone trough all below steps still Toolbar is not working ,can u suggest me ,what else i have to do ,and which file i have to edit with what content?
i changed
config.toolbar = 'Full';
config.toolbar_Full =
['Source','-','Save','NewPage','Preview','-','Templates'],
['Cut','Copy','Paste','PasteText','PasteFromWord','-','Print', 'SpellChecker', 'Scayt'],
['Undo','Redo','-','Find','Replace','-','SelectAll','RemoveFormat'],
['Form', 'Checkbox', 'Radio', 'TextField', 'Textarea', 'Select', 'Button', 'ImageButton', 'HiddenField'],
['Bold','Italic','Underline','Strike','-','Subscript','Superscript'],
['NumberedList','BulletedList','-','Outdent','Indent','Blockquote'],
['JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'],
['Link','Unlink','Anchor'],
['Image','Flash','Table','HorizontalRule','Smiley','SpecialChar','PageBreak'],
['Styles','Format','Font','FontSize'],
['TextColor','BGColor'],
['Maximize', 'ShowBlocks','-','About']
config.toolbar_Basic =
['Bold', 'Italic', '-', 'NumberedList', 'BulletedList', '-', 'Link', 'Unlink','-','About']
Note that two toolbar definitions have been defined, one named "Full" and the other "Basic". The "Full" definition has been set to be used in the toolbar setting.
Toolbar Bands
Every toolbar definition is composed of a series of "toolbar bands" that are grouped in the final toolbar layout. The bands items move together on new rows when resizing the editor.
As you can see in the above definitions, every toolbar band is defined as a separated JavaScript array of strings. Every string indicates toolbar item to be used. Toolbar items are defined by plugins.
You can also include a separator in the toolbar band by including the dash ("-") character on it.
Forcing Row Break
Looking at the "Full" definition you will note some slash ("/") characters between toolbar bands. This slash can be used to force a break at that point, having the next band to be rendered in a new row and not following the previous one.
Customizing the toolbar
A simple way to configure all editors toolbar is by simply adding a custom toolbar definition inside the config.js file, or even better in a separated configuration file (see "Setting Configurations"). The easiest way for that is by simply copying the above "Full" toolbar definition, and strip it down to your needs. For example, the following is a good recommended toolbar definition to have in the config.js file:
config.toolbar = 'MyToolbar';
config.toolbar_MyToolbar =
['NewPage','Preview'],
['Cut','Copy','Paste','PasteText','PasteFromWord','-','Scayt'],
['Styles','Format'],
['Bold','Italic','Strike'],
['Maximize','-','About']
You can create as many toolbar definitions as you want inside the configuration file. Later, based on some criteria, you can decide the toolbar to use for each editor instance. For example, with the following code, two editors are created in the page, each one using a different toolbar:
CKEDITOR.replace( 'editor1',
toolbar : 'MyToolbar'
CKEDITOR.replace( 'editor2',
toolbar : 'Basic'
It's also possible to set the toolbar definition in-page, when creating the editor instance directly. In that case, just assign it to the toolbar setting directly, for example:
toolbar :
['Styles', 'Format'],
['Bold', 'Italic', '-', 'NumberedList', 'BulletedList', '-', 'Link', '-', 'About']
Can i get solution ASAP
Maximizer
i changed
Toolbar Bands
Forcing Row Break
toolbar : 'Basic'
toolbar :
Maximizer
