Hi!
I have developed a nice little filebrowser, and now I need to know how to make it compatible with CKEditor.
What parameters does it need to accept? And what kind of response to return?
In the docs there's a little about that, but NONE about how to integrated an uploader!
Any help appreciated!
Re: Makeing a filebrowser and uploader compatible with CKEditor?
I had the same problem. It took me many hours to find out a solution.
I wrote my own ajax based filebrowser togeter with the jquery extension. Usualy I give my filebrowser-instance a selector and when I press the submit button I change the value of on input box. With ckeditor I found it's a lot more dificult, because I cannot just set the value of an input-field in a dialog in DOM. Also I don't want a pop up, instead I want a javascript-based dialog, like ckeditor uses by itself. But the ckeditor interface only supports pop-ups by default.
Here is what I did for the image-dialog to get it work:
var myeditor = CKEDITOR.appendTo( "myeditor", config ); CKEDITOR.on( "dialogDefinition", function( ev ) { // Take the dialog name and its definition from the event data. var dialogName = ev.data.name; var dialogDefinition = ev.data.definition; // Check if the definition is from the dialog we"re interested on (the "image" dialog). if ( dialogName == "image" ){ // Get a reference to the "Link Info" tab. var infoTab = dialogDefinition.getContents( "info" ); // Add a button to the "info" tab. infoTab.add({ type : "button", label : myeditor.lang.common.browseServer, onClick : function() { var filename = CKEDITOR.dialog.getCurrent().getContentElement("info", "txtUrl").getValue(); dlg("lib/dlg_filemanager.php", { returnval_selector_ckeditor: "txtUrl", file: filename }, "750px", false, true); } }); } });On my filebrowser-submit event I do:
CKEDITOR.dialog.getCurrent().getContentElement("info", "'.$_GET['returnval_selector_ckeditor'].'").setValue(filename);What I still don't know is how to position my custom button next to the URL-input field. What I was missing in the ckeditor api for this code...
CKEDITOR.replace( 'editor1', { filebrowserBrowseUrl : '/browser/browse.php', filebrowserUploadUrl : '/uploader/upload.php' });...,is a possibility to write a function with the filename as returnval insteat of putting a url here.
I hope this helps you.
function select_object (url) { // If url is empty then exit if (!url) return false; var temp_array = window.location.search.substring(1).split('&'), params = {} ; // Get window search arguments as object for (var i = temp_array.length; i-- > 0;) { var tmp = temp_array[i].split('='); params[tmp[0]] = tmp[1]; } if (params.CKEditorFuncNum) { // Call CKEditor function to insert the URL window.opener.CKEDITOR.tools.callFunction(params.CKEditorFuncNum, url); // Close Window window.close(); } }Re: Makeing a filebrowser and uploader compatible with CKEditor?
if(isset($_POST['upload'])){ echo "upload was posted.."; }am I completely wrong here? or what is it that im missing..
