Name: Longtail JW Player Pugin for CKEDITOR 3.4.2
Author:nghe.huavan@gmail.com
Features:
Features:
-Emberm JW Player For Play Multimedia : Youtube, .mp4, .mov, .f4v, .flv, .3gp, .3g2, All Images Format, Streaming........ (JW Player 5.4)
-Support Multi Skin
-Support Select Autoplay Mode
-Support Change Size
-Support Auto Integrated With CKFinder For Browse Server And Upload Video
-Support Quick Preview
Require:
Auto Integrated With CKFinder When Config Susseccful CKFinder
Download
Re: Longtail JW Player Pugin for CKEDITOR 3.4.2
video is placed at the end of document, not in place edition was started?
I have download the Longtail JW Player Plugin for CKEDITOR 3.4.2 and its perfect.
But I cant get the multiple skin get to work only the default skin works.
I hope somebody have the solution.
The jwplayer is showing properly and seems to cache the whole mp3 but it doesn't start streaming that.
No javascript errors at all in the console.
Any ideas?
thanks your works.
thanks your works JW Player Pugin for CKEDITOR
How can i add 'provider' and 'streamer' options your plugin?
thanks.
<script type='text/javascript' src='js/jwplayer-v582011.js'></script> <div id='mediaspace'>This text will be replaced</div>
<script type='text/javascript'>
jwplayer('mediaspace').setup({ 'flashplayer': 'swf/player-v582011.swf', 'image': 'userfiles/images/', 'start': '0', 'autostart': 'true', 'bufferlength': '2', 'provider': 'rtmp', 'file': 'mp4:alpbugdayci01072011/yasakfilm-1.mp4', 'streamer': 'rtmp://www.alpbugdayci.com/vod/mp4:_definst_', 'controlbar': 'bottom', 'width': '590', 'height': '496' });
