Is there any way to load the styles pulldown when the editor loads? The problem is if you click on text in the editor that has a style assigned to it before you select the styles pulldown it will not show the style. When you do click the styles pulldown it takes clicking on a couple different styles before the correct style starts to show up.
This is reproducible with the default styles or custom styles. It can be easily reproduced by loading content into the editor that has styles assigned to it then clicking on the text with the style and you will not see the style show up in the pulldown. I did test this with the nightly build and it has the same problem.
It would be great to get this to work as it does in fckeditor even if there is a slight penalty on the load speed.
Thanks!
Thanks!
