Hi guys,
I'm currently facing a problem with the hyperlink functionnality of the editor.
My client wants to add hyperlinks in the text and be able to click it while edition.
And also beeing able to click on it when they're displayed later in an other editor instance.
The problem is the following, the links are not clickable, but if you click the link while pressing the CTRL key, the link is "working".
But in edit mode, when you use that trick, it opens a new window/tab but nothing is diplayed into it, the url of the page is
Does anyone know if there is a way to avoid the need of pressing CTRL when clicking the link and also why the links are not working in edit mode?
Thanks for your help, this is quite urgent as the customer needs this functionality to work ASAP...
javascript:void(0)/*323*/
Re: Links not clickable
When looking at _source/plugins/link/dialog/link.js I do see a section of the code that contains this type of functionality:
onOk : function() { var attributes = { href : 'javascript:void(0)/*' + CKEDITOR.tools.getNextNumber() + '*/' },I haven't got the logic all figured out yet, but I wanted to at least mention I'm having a similar issue. If I find out more details I'll try and get back to post them.
