Hello!
I can't figure out how to keep my plugin (a rich combo) enabled in source mode.
The code snippet below doesn't work...
Best regards,
Fabian
editor.addCommand( 'myPlugin', { modes : { wysiwyg : 1, source : 1 } });
editor.ui.addRichCombo('MyPlugin', { label : 'MyPlugin', title : 'MyPlugin', className : 'myPlugin', command : 'myPlugin', panel : {...
Best regards,
Fabian
Re: Keep RichCombo enabled in source mode
{label: "Snippit",
title: "Snippit",
modes: { wysiwyg:1, source:1 },
That will keep the combo box enabled in source mode. The next issue is getting the selected text to insert. Currently working on that.
If you're looking to insert text into the source area then refer to this post.
http://cksource.com/forums/viewtopic.php?t=23425
