there is a problem I seem to encounter everytime I try to embed the ckeditor into a plugin view (to check some requirements we need a wysiwyg to fullfill). The JavaScript version does not suit our needs, since the dialogues would be stuck in the browser-area (which will be too small). I then got the java files from github und tried to implement the Java version instead. It did not recognize the state of the currently marked text though. For example a marked text shall be made bold. After pressing the button, it stays "pressed", even if one leaves the textpassage, jumping to another, where the text is normal and vice versa.
I figuered it is some kind of problem with the event-fireing, since it uccured on every single button.
Is this a known problem (I did not find a simular discription in the forum)?
Would be gratefull for any help or suggestions on the dialogue-issue, or the "events" - if I'm right.
Thanks in advance
Jinsei at pure-systems
Thanks in advance
Re: Java implementation event problem
What are you talking about?
