Hi Team,
I am using CKEditor 3.5.1 with CKFinder 2.0.1 in my application and my application is developed using Classic ASP which runs on Windows 2000 server.
I have an issue with image uploading in CKEditor. In my application i use custom encryption technique for encrypting the URL information. The encryption is working fine if i provide plain content without any images attached. If i attach (upload) any images to the content then my encryption is failing. To be specific the Chr() method is failing.
Here is the encryption method that I use in my application.
Function EnCrypt(strCryptThis)
strCryptThis = ChkString(strCryptThis)
Dim strChar, iKeyChar, iStringChar, i
for i = 1 to Len(strCryptThis)
iKeyChar = Asc(mid(Encryption_Key,i,1))
iStringChar = Asc(mid(strCryptThis,i,1))
iCryptChar = iStringChar + iKeyChar
If iCryptChar > 255 then
iCryptChar = iCryptChar - 256
End If
'iCryptChar = iKeyChar Xor iStringChar
strEncrypted = strEncrypted & Chr(iCryptChar)
next
EnCrypt = Server.URLEncode(strEncrypted)
End Function
Here are the outputs received in various cases.
Case #1: Record is saved without image in the content.
Output :
Encryption_Key : _E`IBAV9'3N@:NGF+FW@N6@0RA+\T0RVWZ@ME,N2>&F-:DG$9
strCryptThis : ?SL=Active Server Pages&nSpecialtyID=32465&nTopicID=3357
i:1 iKeyChar:95 iStringChar:63 iCryptChar:158 strEncrypted:ž
i:2 iKeyChar:69 iStringChar:83 iCryptChar:152 strEncrypted:ž˜
i:3 iKeyChar:96 iStringChar:76 iCryptChar:172 strEncrypted:ž˜¬
i:4 iKeyChar:73 iStringChar:61 iCryptChar:134 strEncrypted:ž˜¬†
i:5 iKeyChar:66 iStringChar:65 iCryptChar:131 strEncrypted:ž˜¬†ƒ
i:6 iKeyChar:65 iStringChar:99 iCryptChar:164 strEncrypted:ž˜¬†ƒ¤
i:7 iKeyChar:86 iStringChar:116 iCryptChar:202 strEncrypted:ž˜¬†ƒ¤Ê
i:8 iKeyChar:60 iStringChar:105 iCryptChar:165 strEncrypted:ž˜¬†ƒ¤Ê¥
i:9 iKeyChar:72 iStringChar:118 iCryptChar:190 strEncrypted:ž˜¬†ƒ¤Ê¥¾
i:10 iKeyChar:46 iStringChar:101 iCryptChar:147 strEncrypted:ž˜¬†ƒ¤Ê¥¾“
i:11 iKeyChar:40 iStringChar:32 iCryptChar:72 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H
i:12 iKeyChar:88 iStringChar:83 iCryptChar:171 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«
i:13 iKeyChar:81 iStringChar:101 iCryptChar:182 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶
i:14 iKeyChar:62 iStringChar:114 iCryptChar:176 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°
i:15 iKeyChar:57 iStringChar:118 iCryptChar:175 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯
i:16 iKeyChar:39 iStringChar:101 iCryptChar:140 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ
i:17 iKeyChar:51 iStringChar:114 iCryptChar:165 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥
i:18 iKeyChar:78 iStringChar:32 iCryptChar:110 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n
i:19 iKeyChar:64 iStringChar:80 iCryptChar:144 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n
i:20 iKeyChar:58 iStringChar:97 iCryptChar:155 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›
i:21 iKeyChar:78 iStringChar:103 iCryptChar:181 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ
i:22 iKeyChar:71 iStringChar:101 iCryptChar:172 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬
i:23 iKeyChar:70 iStringChar:115 iCryptChar:185 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹
i:24 iKeyChar:43 iStringChar:38 iCryptChar:81 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q
i:25 iKeyChar:70 iStringChar:110 iCryptChar:180 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´
i:26 iKeyChar:87 iStringChar:83 iCryptChar:170 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª
i:27 iKeyChar:64 iStringChar:112 iCryptChar:176 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°
i:28 iKeyChar:78 iStringChar:101 iCryptChar:179 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³
i:29 iKeyChar:54 iStringChar:99 iCryptChar:153 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™
i:30 iKeyChar:64 iStringChar:105 iCryptChar:169 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©
i:31 iKeyChar:48 iStringChar:97 iCryptChar:145 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘
i:32 iKeyChar:82 iStringChar:108 iCryptChar:190 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾
i:33 iKeyChar:65 iStringChar:116 iCryptChar:181 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ
i:34 iKeyChar:43 iStringChar:121 iCryptChar:164 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤
i:35 iKeyChar:92 iStringChar:73 iCryptChar:165 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥
i:36 iKeyChar:84 iStringChar:68 iCryptChar:152 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜
i:37 iKeyChar:48 iStringChar:61 iCryptChar:109 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m
i:38 iKeyChar:82 iStringChar:51 iCryptChar:133 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…
i:39 iKeyChar:86 iStringChar:50 iCryptChar:136 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ
i:40 iKeyChar:87 iStringChar:52 iCryptChar:139 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹
i:41 iKeyChar:90 iStringChar:54 iCryptChar:144 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹
i:42 iKeyChar:64 iStringChar:53 iCryptChar:117 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹u
i:43 iKeyChar:77 iStringChar:38 iCryptChar:115 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us
i:44 iKeyChar:69 iStringChar:110 iCryptChar:179 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³
i:45 iKeyChar:44 iStringChar:84 iCryptChar:128 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€
i:46 iKeyChar:78 iStringChar:111 iCryptChar:189 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½
i:47 iKeyChar:50 iStringChar:112 iCryptChar:162 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢
i:48 iKeyChar:62 iStringChar:105 iCryptChar:167 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§
i:49 iKeyChar:38 iStringChar:99 iCryptChar:137 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§‰
i:50 iKeyChar:70 iStringChar:73 iCryptChar:143 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§‰
i:51 iKeyChar:45 iStringChar:68 iCryptChar:113 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§‰q
i:52 iKeyChar:58 iStringChar:61 iCryptChar:119 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§‰qw
i:53 iKeyChar:68 iStringChar:51 iCryptChar:119 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§‰qww
i:54 iKeyChar:71 iStringChar:51 iCryptChar:122 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§‰qwwz
i:55 iKeyChar:36 iStringChar:53 iCryptChar:89 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§‰qwwzY
i:56 iKeyChar:57 iStringChar:55 iCryptChar:112 strEncrypted:ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§‰qwwzYp
strEncrypted : ž˜¬†ƒ¤Ê¥¾“H«¶°¯Œ¥n›µ¬¹Q´ª°³™©‘¾µ¤¥˜m…ˆ‹us³€½¢§‰qwwzYp
Server.URLEncode(strEncrypted) : %9E%98%AC%86%83%A4%CA%A5%BE%93H%AB%B6%B0%AF%8C%A5n%90%9B%B5%AC%B9Q%B4%AA%B0%B3%99%A9%91%BE%B5%A4%A5%98m%85%88%8B%90us%B3%80%BD%A2%A7%89%8FqwwzYp
Case #2: Record is saved with image in the content.
Output :
i:1 iKeyChar:95 iStringChar:63 iCryptChar:158 strEncrypted:?
i:2 iKeyChar:69 iStringChar:83 iCryptChar:152 strEncrypted:?S
i:3 iKeyChar:96 iStringChar:76 iCryptChar:172 strEncrypted:?SL
i:4 iKeyChar:73 iStringChar:61 iCryptChar:134 strEncrypted:?SL=
i:5 iKeyChar:66 iStringChar:65 iCryptChar:131 strEncrypted:?SL=A
i:6 iKeyChar:65 iStringChar:99 iCryptChar:164 strEncrypted:?SL=Ac
i:7 iKeyChar:86 iStringChar:116 iCryptChar:202 strEncrypted:?SL=Act
i:8 iKeyChar:60 iStringChar:105 iCryptChar:165 strEncrypted:?SL=Acti
i:9 iKeyChar:72 iStringChar:118 iCryptChar:190 strEncrypted:?SL=Activ
i:10 iKeyChar:46 iStringChar:101 iCryptChar:147 strEncrypted:?SL=Active
i:11 iKeyChar:40 iStringChar:32 iCryptChar:72 strEncrypted:?SL=ActiveH
i:12 iKeyChar:88 iStringChar:83 iCryptChar:171 strEncrypted:?SL=ActiveHS
i:13 iKeyChar:81 iStringChar:101 iCryptChar:182 strEncrypted:?SL=ActiveHSe
i:14 iKeyChar:62 iStringChar:114 iCryptChar:176 strEncrypted:?SL=ActiveHSer
i:15 iKeyChar:57 iStringChar:118 iCryptChar:175 strEncrypted:?SL=ActiveHServ
i:16 iKeyChar:39 iStringChar:101 iCryptChar:140 strEncrypted:?SL=ActiveHServe
i:17 iKeyChar:51 iStringChar:114 iCryptChar:165 strEncrypted:?SL=ActiveHServer
i:18 iKeyChar:78 iStringChar:32 iCryptChar:110 strEncrypted:?SL=ActiveHServern
i:19 iKeyChar:64 iStringChar:80 iCryptChar:144 strEncrypted:?SL=ActiveHServernP
i:20 iKeyChar:58 iStringChar:97 iCryptChar:155 strEncrypted:?SL=ActiveHServernPa
i:21 iKeyChar:78 iStringChar:103 iCryptChar:181 strEncrypted:?SL=ActiveHServernPag
i:22 iKeyChar:71 iStringChar:101 iCryptChar:172 strEncrypted:?SL=ActiveHServernPage
i:23 iKeyChar:70 iStringChar:115 iCryptChar:185 strEncrypted:?SL=ActiveHServernPages
i:24 iKeyChar:43 iStringChar:38 iCryptChar:81 strEncrypted:?SL=ActiveHServernPagesQ
i:25 iKeyChar:70 iStringChar:110 iCryptChar:180 strEncrypted:?SL=ActiveHServernPagesQn
i:26 iKeyChar:87 iStringChar:83 iCryptChar:170 strEncrypted:?SL=ActiveHServernPagesQnS
i:27 iKeyChar:64 iStringChar:112 iCryptChar:176 strEncrypted:?SL=ActiveHServernPagesQnSp
i:28 iKeyChar:78 iStringChar:101 iCryptChar:179 strEncrypted:?SL=ActiveHServernPagesQnSpe
i:29 iKeyChar:54 iStringChar:99 iCryptChar:153 strEncrypted:?SL=ActiveHServernPagesQnSpec
i:30 iKeyChar:64 iStringChar:105 iCryptChar:169 strEncrypted:?SL=ActiveHServernPagesQnSpeci
i:31 iKeyChar:48 iStringChar:97 iCryptChar:145 strEncrypted:?SL=ActiveHServernPagesQnSpecia
i:32 iKeyChar:82 iStringChar:108 iCryptChar:190 strEncrypted:?SL=ActiveHServernPagesQnSpecial
i:33 iKeyChar:65 iStringChar:116 iCryptChar:181 strEncrypted:?SL=ActiveHServernPagesQnSpecialt
i:34 iKeyChar:43 iStringChar:121 iCryptChar:164 strEncrypted:?SL=ActiveHServernPagesQnSpecialty
i:35 iKeyChar:92 iStringChar:73 iCryptChar:165 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyI
i:36 iKeyChar:84 iStringChar:68 iCryptChar:152 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyID
i:37 iKeyChar:48 iStringChar:61 iCryptChar:109 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm
i:38 iKeyChar:82 iStringChar:51 iCryptChar:133 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3
i:39 iKeyChar:86 iStringChar:50 iCryptChar:136 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm32
i:40 iKeyChar:87 iStringChar:52 iCryptChar:139 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm324
i:41 iKeyChar:90 iStringChar:54 iCryptChar:144 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246
i:42 iKeyChar:64 iStringChar:53 iCryptChar:117 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246u
i:43 iKeyChar:77 iStringChar:38 iCryptChar:115 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246us
i:44 iKeyChar:69 iStringChar:110 iCryptChar:179 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usn
i:45 iKeyChar:44 iStringChar:84 iCryptChar:128 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnT
i:46 iKeyChar:78 iStringChar:111 iCryptChar:189 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTo
i:47 iKeyChar:50 iStringChar:112 iCryptChar:162 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTop
i:48 iKeyChar:62 iStringChar:105 iCryptChar:167 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopi
i:49 iKeyChar:38 iStringChar:99 iCryptChar:137 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopic
i:50 iKeyChar:70 iStringChar:73 iCryptChar:143 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopicI
i:51 iKeyChar:45 iStringChar:68 iCryptChar:113 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopicIq
i:52 iKeyChar:58 iStringChar:61 iCryptChar:119 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopicIqw
i:53 iKeyChar:68 iStringChar:51 iCryptChar:119 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopicIqww
i:54 iKeyChar:71 iStringChar:51 iCryptChar:122 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopicIqwwz
i:55 iKeyChar:36 iStringChar:53 iCryptChar:89 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopicIqwwzY
i:56 iKeyChar:57 iStringChar:55 iCryptChar:112 strEncrypted:?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopicIqwwzYp
strEncrypted : ?SL=ActiveHServernPagesQnSpecialtyIDm3246usnTopicIqwwzYp
Server.URLEncode(strEncrypted) : %3FSL%3DActiveHServernPagesQnSpecialtyIDm3246usnTopicIqwwzYp
Can you help in addressing this issue?
Regards,
Sudheer
End If
next
End Function
Output :
Output :
Regards,
Sudheer
Re: Issue with Encryption
Do you have the problem while uploading a new picture, while saving an article, while displaying the page?
Are you sure that the only difference is that thing about an image?
However when using CKEditor without image upload, then there is no issue.
Have you modified the CKFinder code?
Have you tested CKFinder in stand alone mode?
