I've been having some problems getting CKEditor up and running and was hoping someone here might be able to help.
The problems only occur in IE (tested in 6 and 7), Firefox and Safari are both working fine. There are 3 main issues:
1. If I have CKEditor configured for entermode to be CKEDITOR.ENTER_P, there is a Javascript error thrown that states "getSelection().getStartElement() is null or not an object"
2. The Element Path at the bottom of the editor doesn't appear.
3. If I select some text and Bold it, or Italicise it or anything else, I can't undo that. The button doesn't stay highlighted. So if I have text that I subscript, if I click subscript again it just keeps getting smaller and smaller.
I'm assuming there is one underlying problem that is causing it but I can't figure out what that is. The sample scripts work fine, however if I copy and paste the HTML from one of the sample scripts into my page it no longer works.
This is the code I'm using:
Any help would be greatly appreciated!
Thank you,
Eric
<tr>
<td valign="top">
<textarea id="item_summary" cols="75" rows="12" class="textarea" name="item_summary"></textarea>
</td>
<td> </td>
<!-- ! ###EDITOR### -->
//<![CDATA[
var editor = CKEDITOR.replace( 'item_summary',
height:"291", width:"800",
toolbar :
['Bold','Italic','Underline','Strike','-','Subscript','Superscript'],
['NumberedList','BulletedList','-','Outdent','Indent',],
['JustifyLeft','JustifyCenter','JustifyRight','JustifyBlock'],
['TextColor','BGColor']
<td>Any help would be greatly appreciated!
Thank you,
Eric
Re: Internet Explorer - JS Errors and Editor Problems
Turns out another Javascript file was causing a conflict with CKEditor.
The file read:
if (navigator.userAgent.indexOf('MSIE') != -1) var undefined = null;Which CKEditor obviously didn't like.
Maybe this will be helpful to someone in the future.
Cheers
