I'm trying to integrate CKeditor with a Zend Application i'm building.
When I call the ckeditor.js, and it tries to load all the core files, it can't find the core files.
In my console I can see it's looking for the core files in the wrong directory.
Directory where I have all the ckEditor files is:
The console returns this:
Why is it using the complete url, and not the directory from which ckeditor is called as root?
Has anybody any idea on how to fix this issue?
Any help is appreciated, I'm completely stuck here
Application -- Layouts ---- layout.phtml (the 'template' file which loads all the .phtml files into, like insert.phtml form the pages folder, and loads init.js) -- Modules ---- Admin ------ Views -------- Scripts ---------- Pages ------------ insert.phtml (the actual file where I want to use CKEditor) Library Public -- Tinymce ---- tiny_mc.js -- Jquery ---- init.js (loads the ckeditore.js file using this code:
Loading: /dgpcms/public/css/admin/dropdownmenu.css Loaded: /dgpcms/public/css/admin/dropdownmenu.css (4ms) Loading: ../../../ckeditor/ckeditor.js Loaded: ../../../ckeditor/ckeditor.js (514ms) /dgpcms/public/admin/pages/insert/config.js?t=AA4E4NTFailed to load resource: the server responded with a status of 404 (Not Found) /dgpcms/public/admin/pages/insert/skins/kama/editor.css?t=AA4E4NTFailed to load resource: the server responded with a status of 404 (Not Found) /dgpcms/public/admin/pages/insert/lang/en.js?t=AA4E4NTFailed to load resource: the server responded with a status of 404 (Not Found) insert:47Uncaught TypeError: Cannot read property 'options' of undefined
