(function() {
var pluginName = 'customvideo';
CKEDITOR.plugins.add( pluginName,
requires: ['iframedialog'],
init : function( editor )
editor.addCommand( pluginName, {exec:customvideo_onclick});
editor.ui.addButton( 'customvideo', {
label : 'Select video from the library.',
command : pluginName,
icon : this.path + 'images/icon.png'
CKEDITOR.dialog.addIframe('customvideo_dialog', 'Videos', BASE_URI + 'wysiwyg/video',650,500);
editor.addCss(
'img.cke_video' +
'background-image: url(' + CKEDITOR.getUrl( this.path + 'images/placeholder.png' ) + ');' +
'background-position: center center;' +
'background-repeat: no-repeat;' +
'border: 0px;' +
'width: 13px;' +
'height: 13px;' +
afterInit : function( editor )
var dataProcessor = editor.dataProcessor,
dataFilter = dataProcessor && dataProcessor.dataFilter;
if ( dataFilter )
dataFilter.addRules(
elements :
'video' : function( element )
return editor.createFakeParserElement( element, 'cke_video', 'video', true );
function customvideo_onclick(e)
update_instance();
// run when custom button is clicked]
CKEDITOR.currentInstance.openDialog('customvideo_dialog')
var CKEDITOR = window.parent.CKEDITOR;
function insertVideo()
if(replace_html)
replace_html.remove();
source = jQuery('input[name="source"]').val();
width = jQuery('input[name="width"]').val();
height = jQuery('input[name="height"]').val();
auto_start = parseInt(jQuery('input[name="auto_start"]').val()) == 1 ? 'on' : '';
loop = parseInt(jQuery('input[name="loop"]').val() == 1) ? 'true' : '';
url = 'http://example.com/' + source;
var sHTML = "<object class=\"mizu-video\" selThis=\"selThis\" width='"+width+"' height='"+height+"' "+
"classid='CLSID:6BF52A52-394A-11D3-B153-00C04F79FAA6' "+
"codebase='http://www.microsoft.com/Windows/Downloads/Contents/MediaPlayer/' >"+
"<param name='URL' value='"+url+"'>"+
"<param name='autoStart' value='"+ auto_start +"'>"+
" <embed "+
" type='application/x-mplayer2' "+
" pluginspage='http://www.microsoft.com/Windows/Downloads/Contents/MediaPlayer/' "+
" width='"+width+"' "+
" height='"+height+"' "+
" src='"+url+"' "+
" filename='"+source+"' "+
" autostart='"+ auto_start +"' "+
" loop='"+ loop + "' "+
" showstatusbar='"+"0"+"' "+
" showdisplay='"+"0"+"''>"+
" </embed>"+
"</object>";
newnameFakeElement(sHTML);
windowClose();
function newnameFakeElement( html )
var editor = window.parent.instance;
var realElement = CKEDITOR.dom.element.createFromHtml( html );
var fakeElement = editor.createFakeElement( realElement, 'cke_video', 'video', true );
fakeStyle = fakeElement.getAttribute('style') || '';
var width = realElement.getAttribute('width'),
height = realElement.getAttribute('height');
if ( typeof width != 'undefined' )
fakeStyle += 'width:' + ( width ) + 'px;';
if ( typeof height != 'undefined' )
fakeStyle += 'height:' + ( height ) + 'px;';
fakeElement.setAttribute('style', fakeStyle);
editor.insertElement(fakeElement);
function windowClose()
CKEDITOR.dialog.getCurrent().hide();
Re: Inserting (and maintaining fake element placeholders)
my
Anything new about that? I'm still trying to get this, cause I have to finish that System with the editor next week or my client will be very angry...
I'm doing something similar and your suggestion about adding a rule to dataFilter was enough for me. What is it that you need?
I don't know how to write a data filter. That was the problem i had. Can you please share the data filter code you have used with us?
lbrinkma
I created a plugin that inserts an iframe in source, and shows a fake object in the html view. But when I go to the source view, and than back to the html view, the fake object is gone and I see my iframe.
Is there an event listener that can be attached on this action, so I can re-parse my source and render the fake object again, instead the iframe.
specifically, if you defined your plugin...
init : function( editor ) { //This is all the init code where you define contextMenu handlers and double click listeners }, //Add a filter for when we switch from source to HTML mode...this will preserve the "Fake" video element //Note the 4 at the end, the filter in the flash plugin has a vlue of 5, so we only need a 4 to slip in before afterInit : function( editor ) { var dataProcessor = editor.dataProcessor, dataFilter = dataProcessor && dataProcessor.dataFilter; if ( dataFilter ) { //Here we want to add a new filter rule...if the source matches this property, it will be converted dataFilter.addRules( { elements : { 'cke:embed' : function( element ) { //This function is defined outside, we just return null if this element isn't what we want if ( !isVideoEmbed( element ) ) return null; //Otherwise, we return a fake element, this is the element that will be shown in WYSIWYG mode return createFakeElement( editor, element ); } } }, 4); } }Now in the same file, inside the main function() {} crap on the same level (But outside of CKEDITOR.plugins.add), I've defined those functions I used in the above code.
function cssifyLength( length ) { if ( numberRegex.test( length ) ) return length + 'px'; return length; } //This needs to be buffed to seperate from flash elements better function isVideoEmbed( element ) { var attributes = element.attributes; return ( attributes.flashvars != '' ); } function createFakeElement( editor, realElement ) { var fakeElement = editor.createFakeParserElement( realElement, 'cke_flash', 'video', true ), fakeStyle = fakeElement.attributes.style || ''; var width = realElement.attributes.width, height = realElement.attributes.height; if ( typeof width != 'undefined' ) fakeStyle = fakeElement.attributes.style = fakeStyle + 'width:' + cssifyLength( width ) + ';'; if ( typeof height != 'undefined' ) fakeStyle = fakeElement.attributes.style = fakeStyle + 'height:' + cssifyLength( height ) + ';'; return fakeElement; }Hope that helps with figuring out how to add filters. The actual parsing of data onto and off of the fake element is usually on the dialog file. I again recommend looking at flash.js for more on that.
(function() { var wmvFilenameRegex = /\.wmv(?:$|\?)/i, numberRegex = /^\d+(?:\.\d+)?$/; function cssifyLength( length ) { if ( numberRegex.test( length ) ) return length + 'px'; return length; } function isWMVEmbed( element ) { var attributes = element.attributes; return ( attributes.type == 'application/x-ms-wmp' || wmvFilenameRegex.test( attributes.src || '' ) ); } function createFakeElement( editor, realElement ) { var fakeElement = editor.createFakeParserElement( realElement, 'cke_wmv', 'WMVDialog', true ), fakeStyle = fakeElement.attributes.style || ''; var width = realElement.attributes.width, height = realElement.attributes.height; if ( typeof width != 'undefined' ) fakeStyle = fakeElement.attributes.style = fakeStyle + 'width:' + cssifyLength( width ) + ';'; if ( typeof height != 'undefined' ) fakeStyle = fakeElement.attributes.style = fakeStyle + 'height:' + cssifyLength( height ) + ';'; return fakeElement; } CKEDITOR.plugins.add( 'WMV', { init : function( editor ) { editor.addCommand( 'WMV', new CKEDITOR.dialogCommand( 'WMVDialog' ) ); editor.ui.addButton( 'WMV', { label: 'Windows Media Video', command: 'WMV', icon: this.path + 'images/icon_wmv.gif' }); CKEDITOR.dialog.add( 'WMVDialog', this.path + 'dialogs/wmv.js' ); editor.addCss( 'img.cke_wmv' + '{' + 'background-image: url(' + CKEDITOR.getUrl( this.path + 'images/placeholder.png' ) + ');' + 'background-position: center center;' + 'background-repeat: no-repeat;' + 'border: 1px solid #a9a9a9;' + 'width: 80px;' + 'height: 80px;' + '}' ); // If the "menu" plugin is loaded, register the menu items. if ( editor.addMenuItems ) { editor.addMenuItems( { wmv : { label : 'Windows Movie Video', command : 'WMV', group : 'WMV' } }); } editor.on( 'doubleclick', function( evt ) { var element = evt.data.element; if ( element.is( 'img' ) && element.getAttribute( '_cke_real_element_type' ) == 'WMV' ) evt.data.dialog = 'WMVDialog'; }); // If the "contextmenu" plugin is loaded, register the listeners. if ( editor.contextMenu ) { editor.contextMenu.addListener( function( element, selection ) { if ( element && element.is( 'img' ) && !element.isReadOnly() && element.getAttribute( '_cke_real_element_type' ) == 'WMV' ) return { wmv : CKEDITOR.TRISTATE_OFF }; }); } }, afterInit : function( editor ) { var dataProcessor = editor.dataProcessor, dataFilter = dataProcessor && dataProcessor.dataFilter; if ( dataFilter ) { dataFilter.addRules( { elements : { 'cke:object' : function( element ) { var attributes = element.attributes, classId = attributes.classid && String( attributes.classid ).toLowerCase(); if ( !classId ) { // Look for the inner <embed> for ( var i = 0 ; i < element.children.length ; i++ ) { if ( element.children[ i ].name == 'cke:embed' ) { if ( !isWMVEmbed( element.children[ i ] ) ) return null; return createFakeElement( editor, element ); } } return null; } return createFakeElement( editor, element ); }, 'cke:embed' : function( element ) { if ( !isWMVEmbed( element ) ) return null; return createFakeElement( editor, element ); } } }, 5); } }, requires : [ 'fakeobjects' ] }); })(); CKEDITOR.tools.extend( CKEDITOR.config, { /** * Save as EMBED tag only. This tag is unrecommended. * @type Boolean * @default false */ wmvEmbedTagOnly : false, /** * Add EMBED tag as alternative: <object><embed></embed></object> * @type Boolean * @default false */ wmvAddEmbedTag : true, /** * Use embedTagOnly and addEmbedTag values on edit. * @type Boolean * @default false */ wmvConvertOnEdit : false } );(function() { /* * It is possible to set things in three different places. * 1. As attributes in the object tag. * 2. As param tags under the object tag. * 3. As attributes in the embed tag. * It is possible for a single attribute to be present in more than one place. * So let's define a mapping between a sementic attribute and its syntactic * equivalents. * Then we'll set and retrieve attribute values according to the mapping, * instead of having to check and set each syntactic attribute every time. * * Reference: http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_12701 */ var ATTRTYPE_OBJECT = 1, ATTRTYPE_PARAM = 2, ATTRTYPE_EMBED = 4; var attributesMap = { id : [ { type : ATTRTYPE_OBJECT, name : 'id' } ], classid : [ { type : ATTRTYPE_OBJECT, name : 'classid' } ], codebase : [ { type : ATTRTYPE_OBJECT, name : 'codebase'} ], pluginspage : [ { type : ATTRTYPE_EMBED, name : 'pluginspage' } ], src : [ { type : ATTRTYPE_PARAM, name : 'FileName' }, { type : ATTRTYPE_EMBED, name : 'src' } ], name : [ { type : ATTRTYPE_EMBED, name : 'name' } ], align : [ { type : ATTRTYPE_OBJECT, name : 'align' } ], title : [ { type : ATTRTYPE_OBJECT, name : 'title' }, { type : ATTRTYPE_EMBED, name : 'title' } ], 'class' : [ { type : ATTRTYPE_OBJECT, name : 'class' }, { type : ATTRTYPE_EMBED, name : 'class'} ], width : [ { type : ATTRTYPE_OBJECT, name : 'width' }, { type : ATTRTYPE_EMBED, name : 'width' } ], height : [ { type : ATTRTYPE_OBJECT, name : 'height' }, { type : ATTRTYPE_EMBED, name : 'height' } ], hSpace : [ { type : ATTRTYPE_OBJECT, name : 'hSpace' }, { type : ATTRTYPE_EMBED, name : 'hSpace' } ], vSpace : [ { type : ATTRTYPE_OBJECT, name : 'vSpace' }, { type : ATTRTYPE_EMBED, name : 'vSpace' } ], style : [ { type : ATTRTYPE_OBJECT, name : 'style' }, { type : ATTRTYPE_EMBED, name : 'style' } ], type : [ { type : ATTRTYPE_EMBED, name : 'type' } ] }; var names = [ 'showdisplay', 'ShowControls', 'loop', 'AutoStart', 'quality', 'scale', 'salign', 'wmode', 'bgcolor', 'base', 'WMVvars', 'allowScriptAccess', 'showstatusbar' ]; for ( var i = 0 ; i < names.length ; i++ ) attributesMap[ names[i] ] = [ { type : ATTRTYPE_EMBED, name : names[i] }, { type : ATTRTYPE_PARAM, name : names[i] } ]; names = [ 'showdisplay', 'showstatusbar', 'ShowControls', 'loop', 'AutoStart' ]; // This section is not needed as we want all values to be displayed true or false // for ( i = 0 ; i < names.length ; i++ ) // attributesMap[ names[i] ][0]['default'] = attributesMap[ names[i] ][1]['default'] = false; function loadValue( objectNode, embedNode, paramMap ) { var attributes = attributesMap[ this.id ]; if ( !attributes ) return; var isCheckbox = ( this instanceof CKEDITOR.ui.dialog.checkbox ); for ( var i = 0 ; i < attributes.length ; i++ ) { var attrDef = attributes[ i ]; switch ( attrDef.type ) { case ATTRTYPE_OBJECT: if ( !objectNode ) continue; if ( objectNode.getAttribute( attrDef.name ) !== null ) { var value = objectNode.getAttribute( attrDef.name ); if ( isCheckbox ) this.setValue( value.toLowerCase() == 'true' ); else this.setValue( value ); return; } else if ( isCheckbox ) this.setValue( !!attrDef[ 'default' ] ); break; case ATTRTYPE_PARAM: if ( !objectNode ) continue; if ( attrDef.name in paramMap ) { value = paramMap[ attrDef.name ]; if ( isCheckbox ) this.setValue( value.toLowerCase() == 'true' ); else this.setValue( value ); return; } else if ( isCheckbox ) this.setValue( !!attrDef[ 'default' ] ); break; case ATTRTYPE_EMBED: if ( !embedNode ) continue; if ( embedNode.getAttribute( attrDef.name ) ) { value = embedNode.getAttribute( attrDef.name ); if ( isCheckbox ) this.setValue( value.toLowerCase() == 'true' ); else this.setValue( value ); return; } else if ( isCheckbox ) this.setValue( !!attrDef[ 'default' ] ); } } } function commitValue( objectNode, embedNode, paramMap ) { var attributes = attributesMap[ this.id ]; if ( !attributes ) return; var isRemove = ( this.getValue() === '' ), isCheckbox = ( this instanceof CKEDITOR.ui.dialog.checkbox ); for ( var i = 0 ; i < attributes.length ; i++ ) { var attrDef = attributes[i]; switch ( attrDef.type ) { case ATTRTYPE_OBJECT: if ( !objectNode ) continue; var value = this.getValue(); if ( isRemove || isCheckbox && value === attrDef[ 'default' ] ) objectNode.removeAttribute( attrDef.name ); else objectNode.setAttribute( attrDef.name, value ); break; case ATTRTYPE_PARAM: if ( !objectNode ) continue; value = this.getValue(); if ( isRemove || isCheckbox && value === attrDef[ 'default' ] ) { if ( attrDef.name in paramMap ) paramMap[ attrDef.name ].remove(); } else { if ( attrDef.name in paramMap ) paramMap[ attrDef.name ].setAttribute( 'value', value ); else { var param = CKEDITOR.dom.element.createFromHtml( '<cke:param></cke:param>', objectNode.getDocument() ); param.setAttributes( { name : attrDef.name, value : value } ); if ( objectNode.getChildCount() < 1 ) param.appendTo( objectNode ); else param.insertBefore( objectNode.getFirst() ); } } break; case ATTRTYPE_EMBED: if ( !embedNode ) continue; value = this.getValue(); if ( isRemove || isCheckbox && value === attrDef[ 'default' ]) embedNode.removeAttribute( attrDef.name ); else embedNode.setAttribute( attrDef.name, value ); } } } CKEDITOR.dialog.add( 'WMVDialog', function( editor ) { var makeObjectTag = !editor.config.wmvEmbedTagOnly, makeEmbedTag = editor.config.wmvAddEmbedTag || editor.config.wmvEmbedTagOnly; var previewPreloader, previewAreaHtml = '<div>' + CKEDITOR.tools.htmlEncode( editor.lang.common.preview ) +'<br>' + '<div id="cke_WmvPreviewLoader' + CKEDITOR.tools.getNextNumber() + '" style="display:none"><div class="loading"> </div></div>' + '<div id="cke_WmvPreviewBox' + CKEDITOR.tools.getNextNumber() + '" class="FlashPreviewBox"></div></div>'; return { title : 'Windows Media Video', minWidth : 420, minHeight : 310, onShow : function() { // Clear previously saved elements. this.fakeImage = this.objectNode = this.embedNode = null; previewPreloader = new CKEDITOR.dom.element( 'embed', editor.document ); // Try to detect any embed or object tag that has WMV parameters. var fakeImage = this.getSelectedElement(); if ( fakeImage && fakeImage.getAttribute( '_cke_real_element_type' ) && fakeImage.getAttribute( '_cke_real_element_type' ) == 'wmv' ) { this.fakeImage = fakeImage; var realElement = editor.restoreRealElement( fakeImage ), objectNode = null, embedNode = null, paramMap = {}; if ( realElement.getName() == 'cke:object' ) { objectNode = realElement; var embedList = objectNode.getElementsByTag( 'embed', 'cke' ); if ( embedList.count() > 0 ) embedNode = embedList.getItem( 0 ); var paramList = objectNode.getElementsByTag( 'param', 'cke' ); for ( var i = 0, length = paramList.count() ; i < length ; i++ ) { var item = paramList.getItem( i ), name = item.getAttribute( 'name' ), value = item.getAttribute( 'value' ); paramMap[ name ] = value; } } else if ( realElement.getName() == 'cke:embed' ) embedNode = realElement; this.objectNode = objectNode; this.embedNode = embedNode; this.setupContent( objectNode, embedNode, paramMap, fakeImage ); } }, onOk : function() { // If there's no selected object or embed, create one. Otherwise, reuse the // selected object and embed nodes. var objectNode = null, embedNode = null, paramMap = null; if ( !this.fakeImage ) { if ( makeObjectTag ) { objectNode = CKEDITOR.dom.element.createFromHtml( '<cke:object></cke:object>', editor.document ); var attributes = { classid : 'clsid:22d6f312-b0f6-11d0-94ab-0080c74c7e95', codebase : 'https://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=5,1,52,701' }; objectNode.setAttributes( attributes ); } if ( makeEmbedTag ) { embedNode = CKEDITOR.dom.element.createFromHtml( '<cke:embed></cke:embed>', editor.document ); embedNode.setAttributes( { type : 'application/x-ms-wmp', pluginspage : 'https://www.microsoft.com/Windows/MediaPlayer/' } ); if ( objectNode ) embedNode.appendTo( objectNode ); } } else { objectNode = this.objectNode; embedNode = this.embedNode; } // Produce the paramMap if there's an object tag. if ( objectNode ) { paramMap = {}; var paramList = objectNode.getElementsByTag( 'param', 'cke' ); for ( var i = 0, length = paramList.count() ; i < length ; i++ ) paramMap[ paramList.getItem( i ).getAttribute( 'name' ) ] = paramList.getItem( i ); } // A subset of the specified attributes/styles // should also be applied on the fake element to // have better visual effect. (#5240) var extraStyles = {}, extraAttributes = {}; this.commitContent( objectNode, embedNode, paramMap, extraStyles, extraAttributes ); // Refresh the fake image. var newFakeImage = editor.createFakeElement( objectNode || embedNode, 'cke_wmv', 'wmv', true ); newFakeImage.setAttributes( extraAttributes ); newFakeImage.setStyles( extraStyles ); if ( this.fakeImage ) { newFakeImage.replace( this.fakeImage ); editor.getSelection().selectElement( newFakeImage ); } else editor.insertElement( newFakeImage ); }, onHide : function() { if ( this.preview ) this.preview.setHtml(''); }, contents : [ { id : 'info', label : editor.lang.common.generalTab, accessKey : 'I', elements : [ { type : 'vbox', padding : 0, children : [ { type : 'hbox', widths : [ '280px', '110px' ], align : 'right', children : [ { id : 'src', type : 'text', label : editor.lang.common.url, required : true, validate : CKEDITOR.dialog.validate.notEmpty( editor.lang.flash.validateSrc ), setup : loadValue, commit : commitValue, onLoad : function() { var dialog = this.getDialog(), updatePreview = function( src ){ // Query the preloader to figure out the url impacted by based href. previewPreloader.setAttribute( 'src', src ); dialog.preview.setHtml( '<embed height="100%" width="100%" src="' + CKEDITOR.tools.htmlEncode( previewPreloader.getAttribute( 'src' ) ) + '" type="application/x-ms-wmp"></embed>' ); }; // Preview element dialog.preview = dialog.getContentElement( 'info', 'preview' ).getElement().getChild( 3 ); // Sync on inital value loaded. this.on( 'change', function( evt ){ if ( evt.data && evt.data.value ) updatePreview( evt.data.value ); } ); // Sync when input value changed. this.getInputElement().on( 'change', function( evt ){ updatePreview( this.getValue() ); }, this ); } }, { type : 'button', id : 'browse', filebrowser : 'info:src', hidden : true, // v-align with the 'src' field. // TODO: We need something better than a fixed size here. style : 'display:inline-block;margin-top:10px;', label : editor.lang.common.browseServer } ] } ] }, { type : 'hbox', widths : [ '25%', '25%', '25%', '25%', '25%' ], children : [ { type : 'text', id : 'width', 'default' : 300, style : 'width:95px', label : editor.lang.flash.width, validate : CKEDITOR.dialog.validate.integer( editor.lang.flash.validateWidth ), setup : function( objectNode, embedNode, paramMap, fakeImage ) { loadValue.apply( this, arguments ); if ( fakeImage ) { var fakeImageWidth = parseInt( fakeImage.$.style.width, 10 ); if ( !isNaN( fakeImageWidth ) ) this.setValue( fakeImageWidth ); } }, commit : function( objectNode, embedNode, paramMap, extraStyles ) { commitValue.apply( this, arguments ); if ( this.getValue() ) extraStyles.width = this.getValue() + 'px'; } }, { type : 'text', id : 'height', 'default' : 220, style : 'width:95px', label : editor.lang.flash.height, validate : CKEDITOR.dialog.validate.integer( editor.lang.flash.validateHeight ), setup : function( objectNode, embedNode, paramMap, fakeImage ) { loadValue.apply( this, arguments ); if ( fakeImage ) { var fakeImageHeight = parseInt( fakeImage.$.style.height, 10 ); if ( !isNaN( fakeImageHeight ) ) this.setValue( fakeImageHeight ); } }, commit : function( objectNode, embedNode, paramMap, extraStyles ) { commitValue.apply( this, arguments ); if ( this.getValue() ) extraStyles.height = this.getValue() + 'px'; } }, { type : 'text', id : 'hSpace', style : 'width:95px', label : editor.lang.flash.hSpace, validate : CKEDITOR.dialog.validate.integer( editor.lang.flash.validateHSpace ), setup : loadValue, commit : commitValue }, { type : 'text', id : 'vSpace', style : 'width:95px', label : editor.lang.flash.vSpace, validate : CKEDITOR.dialog.validate.integer( editor.lang.flash.validateVSpace ), setup : loadValue, commit : commitValue } ] }, { type : 'vbox', children : [ { type : 'html', id : 'preview', style : 'width:95%;', html : previewAreaHtml } ] } ] }, { id : 'Upload', hidden : true, filebrowser : 'uploadButton', label : editor.lang.common.upload, elements : [ { type : 'file', id : 'upload', label : editor.lang.common.upload, size : 38 }, { type : 'fileButton', id : 'uploadButton', label : editor.lang.common.uploadSubmit, filebrowser : 'info:src', 'for' : [ 'Upload', 'upload' ] } ] }, { id : 'properties', label : editor.lang.flash.propertiesTab, elements : [ { type : 'hbox', widths : [ '50%', '50%' ], children : [ { id : 'align', type : 'select', label : editor.lang.flash.align, 'default' : '', style : 'width : 100%;', items : [ [ editor.lang.common.notSet , ''], [ editor.lang.flash.alignRight , 'right'], [ editor.lang.flash.alignLeft , 'left'] ], setup : loadValue, commit : function( objectNode, embedNode, paramMap, extraStyles, extraAttributes ) { var value = this.getValue(); commitValue.apply( this, arguments ); value && ( extraAttributes.align = value ); } }, { type : 'html', html : '<div></div>' } ] }, { type : 'fieldset', label : CKEDITOR.tools.htmlEncode( 'variables for WMV files' ), children : [ { type : 'vbox', padding : 0, children : [ { type : 'checkbox', id : 'AutoStart', label : 'Auto Start', 'default' : false, setup : loadValue, commit : commitValue }, { type : 'checkbox', id : 'ShowControls', label : 'Show Controls', 'default' : true, setup : loadValue, commit : commitValue }, { type : 'checkbox', id : 'loop', label : 'Loop', 'default' : false, setup : loadValue, commit : commitValue }, { type : 'checkbox', id : 'showstatusbar', label : 'Show Status Bar', 'default' : false, setup : loadValue, commit : commitValue }, { type : 'checkbox', id : 'showdisplay', label : 'Show Display', 'default' : false, setup : loadValue, commit : commitValue } ] } ] } ] }, { id : 'advanced', label : editor.lang.common.advancedTab, elements : [ { type : 'hbox', widths : [ '45%', '55%' ], children : [ { type : 'text', id : 'id', label : editor.lang.common.id, setup : loadValue, commit : commitValue }, { type : 'text', id : 'title', label : editor.lang.common.advisoryTitle, setup : loadValue, commit : commitValue } ] }, { type : 'hbox', widths : [ '45%', '55%' ], children : [ { type : 'text', id : 'bgcolor', label : editor.lang.flash.bgcolor, setup : loadValue, commit : commitValue }, { type : 'text', id : 'class', label : editor.lang.common.cssClass, setup : loadValue, commit : commitValue } ] }, { type : 'text', id : 'style', label : editor.lang.common.cssStyle, setup : loadValue, commit : commitValue } ] } ] }; } ); })();Re: Inserting (and maintaining fake element placeholders)
Open to ideas.
Still plugging away at it
afterInit : function( editor ) { var dataProcessor = editor.dataProcessor, dataFilter = dataProcessor && dataProcessor.dataFilter; if ( dataFilter ) { dataFilter.addRules( { elements : { 'cke:object' : function( element ) { var attributes = element.attributes, classId = attributes.classid && String( attributes.classid ).toLowerCase(); if ( !classId ) { // Look for the inner <embed> for ( var i = 0 ; i < element.children.length ; i++ ) { if ( element.children[ i ].name == 'cke:embed' ) { if ( !isWMVEmbed( element.children[ i ] ) ) return null; return createFakeElement( editor, element ); } } return null; } return createFakeElement( editor, element ); }, 'cke:embed' : function( element ) { if ( !isWMVEmbed( element ) ) return null; return createFakeElement( editor, element ); } } }, 5); } },Re: Inserting (and maintaining fake element placeholders)
As always I've no time to spend on this and that is the reason for the late reply.
And again this is an yet another guess. It's clear that you loose the placeholder image. You could try adding the flash plugin again and edit that dataProcessor.
The real problem is that Fake Element is not document enough, as far as I remember. This should have changed now, but I don't think so.
lbrinkma
I've got the same problem....
I'm trying to find a solution second day with few results..
I also found out that flash plugin seems to overwrite the rule for 'cke:embed' element.
Even though the function addRules does take priority as a second argument it seems to be ignored. Probably it's a bug.
The only way I found out how to overwrite a rule for 'cke:embed' element was to remove a part of code from ckeditor.js which is very bad way to do this I guess.
