I am using the insertHtml method to inject html pieces onto the editor but only in IE, the injected code receives an outline with re-size and move functionality (occurs when the html includes elements such as tables, dl, dd, dt etc). This does not happen on Chrome/FF.
Is there a way to disable said functionality or eliminating the outline altogether ?
Thank you in advance
Re: IE: Disabling resize and move functionality on insertHtm
http://docs.cksource.com/ckeditor_api/symbols/CKEDITOR.config.html#.disableObjectResizing
I don't have any other suggestions.
Joe
However, the way I was able to fix this is to add the CSS shown below to my editor. This works for me since my editor is fixed on the page. Don't know if it would work for inline editors.
body.cke_show_borders { position: fixed; }
