<div style="text-align: center; width: 800px; background: url('http://symple2.com/editor_images/image_c88658f6/Patterson Farms/Fresh Produce/PattersonProduceEadsmallheader_02_419.jpg') repeat-y scroll left top transparent;">
test</div>
Fri, 05/27/2011 - 18:15
Re: Huge issue, background:url() get stripped on ie8-
I don't think that there are any changes about how inline styles are handled.
But not i am not 100% sure,
also I thought it could be one of the new plugin.I disabled docprop, same problem, but I can't disable showblock since its built-in
http://rev.ckeditor.com/
Its been an issue for sometimes, 5X00 gave me the same problem
However, I found that 4020 was working the first time you came back from the source, it would still break if you hit 2 time the source button..
Anyway, hope it helps.
