I need to be able to transform data coming from the server into HTML for the editor before that editor's instance is created.
The text from the server is in a rich text format which I want to be treated as plain text when transformed.
How would I do this?
Re: How to use pastplaintext without a dialog instance
If I set the rich text to the editor instance is there a way to pragmatically convert the text to HTML. Similar to the pasttext plugin where the clipboard is substituted with the instance's text?
