Hi Guys,
Anyone can guide me how to sync data with ckeditor and codemirror?
I am using tabs style with show & hide tab panel containers.
I have two tabs which is for "CKEditor" and "CodeMirror".
I have installed ckeditor and codemirror inside my tab panels.
Hope I can get some helps or sample of codes that can sync both data at the same time.
Many thanks!
Many thanks!
Re: How to sync data with ckeditor and codemirror?
(function () { var plugin = CKEDITOR.plugins.codemirror; CKEDITOR.plugins.add('codemirror', { requires: ['sourcearea'], init: function (editor) { var thisPath = this.path; editor.on('mode', function () { if (editor.mode == 'source') { var txtarea = editor.textarea.$; //get the native source-mode textarea txtarea.style.display = "none"; //hide it var containerTd = txtarea.parentNode; //get the containing TD //we need to embed a new iframe and document to avoid CKE styles so make a new iframe and replace native source-mode textarea var ifrm = document.createElement('iframe'); with (ifrm) { id = 'cm2'; frameborder = '0'; frameBorder = '0'; src = thisPath + "codemirror.html"; name = editor.name; with (style) { height = '100%'; width = '100%'; } }; containerTd.replaceChild(ifrm, txtarea); editor.on('beforeCommandExec', function (e) {//about to leave source-mode e.removeListener(); //only trigger once e.editor.setData(ifrm.contentWindow.cmInstance.getValue()); //set the editor html e.editor.fire('dataReady'); //data is ready }); } }); } }); })();
