Hello there,
I'm trying to replace an element (<plugin></plugin>) completely by another element (<div>).
I use dataFilter to catch the plugin element but can't make it any further.
Is there a working example somewhere?
I use
To create the div and fill it with content by using
It works this far. I tried to use the CKEditor method
But this will fail silently.
Any help is appreciated, this has to be something someone did before..
I use
var element = new CKEDITOR.dom.element('div', editor.document );To create the div and fill it with content by using
element.setHTML(html);
element.replace(oldElement);
Re: How to replace an element with a div (and vice versa)
