It will only display the menu items listed (the default list is a lot longer) - I needed this because I had to disable a lot of table menuItems. I guess you can also disable some of them by using the
config.removePlugins
Also look at the plugins/menu/plugin.js file (this is where the menu_groups is defined)
Re: How to remove the right click menu?
P.s.
thanks for your answer
