Is there a way to load plugin in CKEditor, if plugin is not located under CKEditor's plugins path.
In FCKEditor I could use FCKConfig.Plugins.Add function to do that
For example:
Line above is placed in custom FCKEditor configuration. I want to do the same for CKEditor custom configuration. Is there possibility to do the same in CKEditor?
For example:
FCKConfig.Plugins.Add( '{pluginname}', '{lang_en}', {path_to_plugin_parent_folder}) ;Line above is placed in custom FCKEditor configuration. I want to do the same for CKEditor custom configuration. Is there possibility to do the same in CKEditor?
Re: How to load plugin if plugin is not in plugins folder
forum
CKEDITOR.plugins.addExternal('{plugin_name}', {plugin_folder_where_plugin.js_resides});CKEDITOR.editorConfig = function(config){ config.extraPlugins = '{plugin_names_seperated_my_commas}'; config.toolbar = [ [ 'Bold', 'Italic', '-', 'NumberedList', 'BulletedList', '-', 'Link', 'Unlink' ], // or some other default toolbars [ '{plugin_name}' ] ]; };Plugins - Load on demmand ?
I downloaded the full version of CKEditor and realized that the plugins folder contains many plugins that I wont use. When I instanciate the editor, these plugins are referenced to that point? I ask because I know that I have to load ckeditor in my application by default (ckeditor.js). But when I want to use a plugin or other it's load on demmand? My concern is about performance of my app.
Rodrigo
Some parts load on demand,
Some parts load on demand, like the plugin dialogs. Best way to minimize the editor is to use gzip on your server. It will drop the size to around 130kb. And make a custom CKEditor version using CKBuilder.
Custom CKEditor with CKBuilder
Thanks sebstefanov for answer my question !! I'll make a custom CKEditor version using CKBuilder as you said.
Best Regards!
