How ro get reference of dom element where cursor is currently positioned. I need to use reference of dom element to add style attributes to it.
Suppose current curser position is after 'Rah' in ckeditor.
How can I get reference of span element surrounding "Rah".
Thanks.
<div><span>Rahul</span></div>
Thanks.
Re: How to get reference of dom element where cursor is plac
where your_editor probably is "this" if you use that code from within CKEditor.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <!-- Copyright (c) 2003-2010, CKSource - Frederico Knabben. All rights reserved. For licensing, see LICENSE.html or http://ckeditor.com/license --> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <title>API usage - CKEditor Sample</title> <meta content="text/html; charset=utf-8" http-equiv="content-type" /> <script type="text/javascript" src="../ckeditor.js"></script> <script src="sample.js" type="text/javascript"></script> <link href="sample.css" rel="stylesheet" type="text/css" /> <script type="text/javascript"> //<![CDATA[ // The instanceReady event is fired when an instance of CKEditor has finished // its initialization. CKEDITOR.on( 'instanceReady', function( ev ) { // Show the editor name and description in the browser status bar. document.getElementById( 'eMessage' ).innerHTML = '<p>Instance "' + ev.editor.name + '" loaded.<\/p>'; // Show this sample buttons. document.getElementById( 'eButtons' ).style.visibility = ''; }); function InsertHTML() { // Get the editor instance that we want to interact with. var oEditor = CKEDITOR.instances.editor1; [b][size=150]alert(oEditor.getSelection()); //null is returned in IE[/size][size=150][/size][/b] } //]]> </script> </head> <body> <h1> CKEditor Sample </h1> <!-- This <div> holds alert messages to be display in the sample page. --> <div id="alerts"> <noscript> <p> <strong>CKEditor requires JavaScript to run</strong>. In a browser with no JavaScript support, like yours, you should still see the contents (HTML data) and you should be able to edit it normally, without a rich editor interface. </p> </noscript> </div> <form action="sample_posteddata.php" method="post"> <p> This sample shows how to use the CKeditor JavaScript API to interact with the editor at runtime.</p> <textarea cols="80" id="editor1" name="editor1" rows="10"><p>This is some <strong>sample text</strong>. You are using <a href="http://ckeditor.com/">CKEditor</a>.</p></textarea> <script type="text/javascript"> //<![CDATA[ // Replace the <textarea id="editor1"> with an CKEditor instance. var editor = CKEDITOR.replace( 'editor1' ); //]]> </script> <div id="eMessage"> </div> <div id="eButtons" style="visibility: hidden"> <input onclick="InsertHTML();" type="button" value="Insert HTML" /> </div> </form> <div id="footer"> </body> </html>Re: How to get reference of dom element where cursor is plac
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <!-- Copyright (c) 2003-2010, CKSource - Frederico Knabben. All rights reserved. For licensing, see LICENSE.html or http://ckeditor.com/license --> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <title>API usage - CKEditor Sample</title> <meta content="text/html; charset=utf-8" http-equiv="content-type" /> <script type="text/javascript" src="../ckeditor.js"></script> <script src="sample.js" type="text/javascript"></script> <link href="sample.css" rel="stylesheet" type="text/css" /> <script type="text/javascript"> //<![CDATA[ // The instanceReady event is fired when an instance of CKEditor has finished // its initialization. CKEDITOR.on( 'instanceReady', function( ev ) { // Show the editor name and description in the browser status bar. document.getElementById( 'eMessage' ).innerHTML = '<p>Instance "' + ev.editor.name + '" loaded.<\/p>'; // Show this sample buttons. document.getElementById( 'eButtons' ).style.visibility = ''; }); function InsertHTML() { // Get the editor instance that we want to interact with. var oEditor = CKEDITOR.instances.editor1; alert(oEditor.getSelection()); //null is returned in IE } //]]> </script> </head> <body> <h1> CKEditor Sample </h1> <!-- This <div> holds alert messages to be display in the sample page. --> <div id="alerts"> <noscript> <p> <strong>CKEditor requires JavaScript to run</strong>. In a browser with no JavaScript support, like yours, you should still see the contents (HTML data) and you should be able to edit it normally, without a rich editor interface. </p> </noscript> </div> <form action="sample_posteddata.php" method="post"> <p> This sample shows how to use the CKeditor JavaScript API to interact with the editor at runtime.</p> <textarea cols="80" id="editor1" name="editor1" rows="10"><p>This is some <strong>sample text</strong>. You are using <a href="http://ckeditor.com/">CKEditor</a>.</p></textarea> <script type="text/javascript"> //<![CDATA[ // Replace the <textarea id="editor1"> with an CKEditor instance. var editor = CKEDITOR.replace( 'editor1' ); //]]> </script> <div id="eMessage"> </div> <div id="eButtons" style="visibility: hidden"> <input onclick="InsertHTML();" type="button" value="Insert HTML" /> </div> </form> <div id="footer"> </body> </html>Re: How to get reference of dom element where cursor is plac
