Is is possible to create an HTML comment that cannot be deleted by the editor in its normal mode.
In source mode, I assume that anything can be added, deleted or modified but in the normal oprating mode of ckeditor, I need to be able to preserve some content even if the user types control-a and then presses delete.
Re: How to create an undeleteable comment
Next I added a div tag enclosing the entire contents with the contenteditable="false" and the entire content was not editable but the delete key allowed me to delete the entire contents enclosed by the div tag.
I would like to store metadata in an html comment tag and I was hoping that there was a way to protect it so that it could not easily be removed unless you go into souce mode and edited it out.
