I create a select element at the bottom of a new tab, which is at the same line with the OK and Cancel buttons. I set the layout of the select element to horizontal so that the label and the select options are at the same line. However, when I want to change the position of the element with style: 'margin-top: 10px', the label does not move but the dropdown move 10px downward. I want to know how to move the label and the dropdown menu at the same time? Thank u ~~~
Fri, 09/09/2011 - 17:57
Re: How to change the position of select element
Have you tried grouping them and styling the container instead?
