As I understand CKEditor works by simply replacing a <textarea> and html is then sent to the POST request when a user hits submit. Of course, then a user could simply submit his own html in a custom POST request and this html can have javascript, tags I don't allow and invalid xhtml.
So clearly I need something on the server side to ensure only certain xhtml tags have been submitted and the xhtml is valid without any javascript. How do others handle this? Is there a good library, preferably Java for this?
Re: How best to deal with security issues and CKEditor?
Probably the simplest solution would be to attempt to prevent the user from doing anything custom. For instance: remove the Source plugin. The editor, by default, can produce a number of different dtds, including HTML 4.01 Strict and Transitional as well as XHTML 1.0 Strict and Transitional.
Using those two in concert with each other should produce a bit more favorable results.
I wonder how normal it is for web apps to completely rely on a client library like CKEditor to do all the validation? How easy it is for others to take advantage..
PHP
strip_tags function
HTML Tidydevshed article
ASP.NET
WebProNews article
public static string StripHtml(string html, bool allowHarmlessTags) { if (html == null || html == string.Empty) return string.Empty; if (allowHarmlessTags) return System.Text.RegularExpressions.Regex.Replace(html, "", string.Empty); return System.Text.RegularExpressions.Regex.Replace(html, "<[^>]*>", string.Empty); }Re: How best to deal with security issues and CKEditor?
And the checks based on regexp are usually too simple for a real attacker. The best way to do it is to take the incoming data, parse it into a DOM tree and then filter out any node or attribute that it isn't whitelisted. Then you get that again as a HTML string and that's the final data.
Any other approach is vulnerable to browser bugs that allows to execute code in a ways that you didn't expect.
For example I think that some site suffered an attack because something like
<scri pt>alert('hello');</scri pt>is executed in IE. Maybe that's not exactly the correct syntax, but it was something that a simple regexp looking for "script" couldn't find. If the cleanup is base only on allowing a set of tags and attributes then it will be safe (or at least much safer, there's nothing perfect)
What are good DOM parsers for this approach in Java?
If CKEditor can do this, then I think the best approach is to simply design an XML schema that I compare the submitted xhtml document to on the server side. Then if it fails, I report an error back to the browser as clearly they very likely circumvented the CKEditor...
If CKEditor cannot do this, then I still like the XML schema approach but then I want to tell the user exactly why their document failed (e.g. we don't support the script tag or the onsubmit attribute). Is there a decent java XML schema validator that can report reasons for failing to validate?
Does this make sense?
Could you please elaborate what exactly this means: "take the incoming data, parse it into a DOM tree and then filter out any node or attribute that it isn't whitelisted".
On the server side I do the following to validate the submitted values:
$allowed_html="<strong><p><a><ul><ol>";
$value = mysql_real_escape_string(strip_tags(html_entity_decode($_POST['value']),$allowed_html));
I have disabled the SOURCE button in CKEditor. But users can still type/paste in html tags. The editor encodes these so I use the decode, strip all non allowed tags, make it database safe and write it into the database. Am I missing anything essential to make it secure?
Thanks, Jens
