My code:
In the php-page that contains CKEditor:
<head>
<title>CMS</title>
<meta content="text/html; charset=utf-8" http-equiv="content-type"/>
<meta name="robots" content="noindex, nofollow"/>
<link href="css/styles.css" rel="stylesheet" type="text/css"/>
<script type="text/javascript" src="jquery-1.4.2.min.js"></script>
<script type="text/javascript" src="jquery.form.js"></script>
// prepare the form when the DOM is ready
$(document).ready(function()
// bind form using ajaxForm
$('#myForm').ajaxForm
// target identifies element that contains txt that the xml-file is saved
target: '#message',
// success identifies the function to invoke when the server response
// has been received; here we apply a fade-in & delayed fade-out effect to the new content
success: function()
//fadeIn txt xml is saved
$('#message').fadeIn('fast');
//fadeOut txt xml is saved
$('#message').delay(2500).fadeOut('slow');
</head>
<body>
<h1>
CKEditor Sample
</h1>
<!-- <div> contains alert message. -->
<div id="alerts">
<noscript>
<p>
<strong>CMS needsJavaScript</strong>.
</p>
</noscript>
</div>
<form id="myForm" action="sparaxml.php" method="post">
<p>
<?php
// Include CKEditor php.
include_once "ckeditor.php";
//Load XML
$xml = simplexml_load_file('xml/home.xml');
//Conent
$initialValue = $xml;
// Class instance.
$CKEditor = new CKEditor();
// Path to ckeditor.js:
$CKEditor->basePath = '';
// configure CKEditor
$CKEditor->Config['customConfig'] = 'config.js';
// Create textarea element och attach CKEditor.
$CKEditor->editor("contentHome", $initialValue);
<input type="submit" value="Save"/>
</p>
</form>
<div id="message"></div>
</body>The php-file that saves to xml-file:
$xmlData = $_POST["contentHome"];
$content = "<?xml version='1.0' encoding='utf-8'?>\r\n<text><![CDATA[" . $xmlData . "]]></text>";
$filename = 'xml/home.xml';
// Let's make sure the file exists and is writable first.
if (is_writable($filename))
// We're opening $filename in writable mode.
if (!$handle = fopen($filename, 'w'))
echo '<div style="background-color:#E0E0E0; padding:20px"><p>FEL:Kan inte öppna filen ($filename)</p></div>';
exit;
// Write $content to our opened file.
if (fwrite($handle, $content) === FALSE)
echo '<div style="background-color:#E0E0E0; padding:20px"><p>FEL:Kan inte skriva till filen.</p></div>';
exit;
echo '<div style="background-color:#F5EFE5; padding:20px"><p>Uppdateringen är sparad.</p></div>';
fclose($handle);
else
echo '<div style="background-color:#E0E0E0; padding:20px"><p>FEL:Filen är inte skrivbar.</p></div>';
