Hi everybody!
I want to write a script to do the following: insert text before and after a selected document block at wysiwyg mode (like bbcode's fuction, ex, in this forum). I have tried to read CKEDITOR.dom.selection, CKEDITOR.dom.range... but that realy difficult. Somebody help me. Thank you very much!
That my example:
you select that document at wysiwyg mode:
Then you call the script, it will insert like:
That my example:
This is the example document! It can be multiline, or multi block
[beforetag]This is the example document! It can be multiline, or multi block[/closetag]
