Hi, all. I'm looking to make a new plugin that basically combines most of the font options into the tabs of a single menu window. In other words, you'd press a button labeled "FONT OPTIONS", and a popup would appear with tabs labeled "Font Color", "Font Face", "Background Color", etc. When you clicked on the Font Color or Background Color tabs, you would see the color picker that you get from the current TextColor/BGColor buttons; when you clicked on Font Face, you would see a dropdown list of font names, like the one that currently shows up with the Font button.
Has anyone done this kind of thing successfully? Made a plugin that CONTAINED other plugins this way? Do I really have to reinvent the wheel and write my own colorpicker from scratch and slot it into the contents of my new plugin?
Re: Help Combining Plugins in the Menu
It seems do-able, but will take a lot of work...maybe there's an easier way...
I try to integrate a color picker in plugin ckeditor,
has what is possible
and is the best way quellle
thank you for your help
