When a user submits code that contains <> they are converted to < and > in the source. They are displayed as < > in the editor. This is how it should be. The user presses submit, it saves to the database with the html encoded values (< >) and displays with the encoded values fine. When the user goes to edit his post, CKEditor takes those < > values and converts them back to < > and they disappear from the editor completely.
A user typed this in a post:
Which is encoded (and saved in the database) as:
When the user goes to edit, CKEditor takes those values and converts them back to < and >. Because they are a <location> tag with no meaning, they disappear. I've verified that the text in the text area is still html_encoded all the way up until the value is given to the textarea.
I've messed around the the config.entities option which seems to have no effect either way. What can I do to prevent CKEditor from decoding these entities when supplying a value to the text-area for editing?
<location> AddOutputFilterByType DEFLATE text/html text/plain text/xml text/x-js text/css </location>
<location> .... </location>
Re: HTML Entities Problem - &lt; &gt;
$message = str_replace('<', '&lt;', $message); $message = str_replace('>', '&gt;', $message);Like I said, I don't like it but config.entities does nothing. I would expect when that is set to false that no output is converted.
Same problem here - 5 years later - still no decent solution
I have the same problem - here's what comes from the database:
<pre data-pbcklang="html" data-pbcktabsize="4"> <code class="language-html "><p> <a href="#">Test</a> </p></code></pre>and when loaded to ckeditor - is converted to:
Could someone on the editor team have a look at this problem please?
ACF seems to be changing your
ACF seems to be changing your code. You can customize it by following this guide. Add config.allowedContent = true; to the config.js file to see if that helps, though it's not recommended leaving it like that.
It was additional htmlentities() function that was needed
Apparently I had to re-encode the entities to convert < to &lt; on editor load - this solved the problem. Thanks for the suggestion @sebstefanov - appreciate it.
