I've created a dropdown with: requires : [ 'richcombo', 'styles' ], similar to the SIZE dropdown in the CKEDITOR toolbar.
The issue I'm having is that after the user select an item from the dropdown, I want the dropdown to reset. I think this can be done by at the END of the onClick:
this.setValue( '', defaultLabel);
Problem is defaultLabel isn't defined anywhere and I'm not sure how to define it to nothing, meaning no selection.
The reason I ask is that sometimes this ends up breaking the styling in CKEDITOR... If you highly all the way to the end of the text in the editor, it makes it so what whenever you type you're in the span I added above which I don't want. I want the span to be inserted, wrapped around the selected text, and for the user's cursor and typing to happen AFTER the span.
Ideas? Thxs
Ideas? Thxs
