Hi, i've created the following plugin. The youtube.html page simply contains a textbox with an id "url" which allows you to enter the url to a YouTube video and it will add some markup inside the editor. When you click "OK" it inserts the code correctly and renders the image fine but when you switch to source code and back to the wysiwyg view the image disappears. I've been looking at the existing plugins such as the page break and flash ones which does something similar but nothing seems to work.
Appreciate it if someone could help. Thanks
(function() {
CKEDITOR.plugins.add('youtube', {
requires : ['iframedialog', 'fakeobjects'],
init : function(editor) {
var iframeWindow = null;
var me = this;
CKEDITOR.dialog.add('youtube_dialog', function() {
return {
title : 'YouTube Movie Properties',
minWidth : 550,
minHeight : 200,
contents : [{
label : 'Insert YouTube Movie',
expand : true,
elements : [{
type : 'iframe',
src : me.path + 'dialogs/youtube.html',
width : '100%',
height : '100%',
onContentLoad : function() {
iframeWindow = document.getElementById(this._.frameId).contentWindow;
onOk : function() {
this._.editor.insertHtml('<cke:youtube url="' + iframeWindow.document.getElementById('url').value + '">YouTube Video Place Marker</cke:youtube>');
editor.addCommand('youtube', new CKEDITOR.dialogCommand('youtube_dialog'));
editor.ui.addButton('YouTube', {
command : 'youtube',
icon : this.path + 'images/icon.gif'
editor.addCss('img.cke_youtube {' +
'width: 80px;' +
'height: 80px;' +
'background: url(' + CKEDITOR.getUrl(this.path + 'images/placeholder.png') + ') no-repeat center center;' +
'border: solid 1px #A9A9A9;' +
afterInit : function(editor) {
var dataProcessor = editor.dataProcessor,
dataFilter = dataProcessor && dataProcessor.dataFilter;
if (dataFilter) {
dataFilter.addRules({
elements : {
'cke:youtube' : function(element) {
return editor.createFakeParserElement(element, 'cke_youtube', 'youtube');
}, 5);
Re: FakeImage Problem with Plugins
I haven't tried it.
in my config.js file which should accomplish this task. I'd appreciate the help once more.
Notice i added the youtube tag to the protected elements regex. I realize these files are only the source code version and that the ckeditor.js contains the actual code and i made the change there aswell. But the fake image still disappears as you come in and out of source view.
Appreciate the help. Thanks
