I'm in the process of converting from FCKeditor to CKeditor and CKfinder. The CKeditor part was easy but CKfinder is proving to be a bit more of a challenge.
The first problem is setting the baseUrl. Is the config file the only way to set the baseUrl? I managed to set it using session variables but I was wondering if there is a better way?
The second problem is converting existing FCK directory structures for uploaded files to CKfinder resource types. Do I have to add custom resource types for each directory the user has created? What about nested directories?
