EditorAreaCSS not finished loading when editor is created.
<?php
global $base_url;
<script type="text/javascript" src="<?php echo($base_url)?>/plugins/ckeditor/ckeditor.js"></script>
<?php
function wysiwyg_input($inputname,$preload,$width,$height)
echo("<textarea id=\"$inputname\" name=\"$inputname\" class=\"ckeditor\" rows=$height cols=$width>");
echo(stripslashes($preload));
echo("</textarea>");
config.EditorAreaCSS = 'http://localhost/aktiv_2010/templates/aktiv/style.css' ;
config.BaseHref = 'http://localhost/aktiv_2010/';
config.language = 'de';
// config.uiColor = '#AADC6E';
Re: EditorAreaCSS not finished loading when editor is created.
<script> CKEDITOR.tools.setTimeout( function() { CKEDITOR.replace('<?php echo($inputname);?>'); },5000); </script>this would give the script 5 seconds to download the css file, doesn't work.
Still need to go into fullscreen, and then back to normal mode to apply the stylesheet.
EditorAreaCss has now changed to ContentsCss.
Hope that still helps.
RT
For me, the problem is more likely to occur when the .css are not in the browser cache. Can you load the .css in the container page to get them into the local cache before you do the .replace?
Your timeout won't help as the download of the .css does not occur until after you .replace. As a kludge, how about putting the editor inside a div style="display:none", do the replace and then 5 seconds after the .replace do a display:block the div? Terrible, terrible kludge, but it would get you up and running until a real solution is found.
