I'm trying to use CKEditor on an ASP.NET page on an <asp:textbox textmode="multiline"... /> control.
I have the ckeditor.js file in a subfolder /js/ckeditor and include the file in my .aspx page using:-
Page.ClientScript.RegisterClientScriptInclude("ckEditor.js", "/js/ckeditor/ckeditor.js");
The editor renders to the screen, but incorrectly. The toolbar is appearing vertically and the textarea overlaps part of the toolbar at the bottom. It looks all wrong. When I check the Error Console in FireFox it shows an error of:-
Error: uncaught exception: [Exception... "Component returned failure code: 0x80004005 (NS_ERROR_FAILURE) [nsIDOMLocation.host]" nsresult: "0x80004005 (NS_ERROR_FAILURE)" location: "JS frame :: XPCSafeJSObjectWrapper.cpp :: anonymous :: line 450" data: no]
The toolbar appears the same in IE8. If I view one of the sample files, it works fine.
Any ideas how I can fix this problem?
Re: Editor not rendering correctly
