Dear,
i use CKeditor on my oscommerce webshop.
I downloaded the last package and installed it everything works except the double enter
Now is the problem when i insert tekst like this.
This is the tekst
This is the tekst
This is the tekst
This is the tekst
He saves it as:
This is the tekst
This is the tekst
This is the tekst
This is the tekst
I tried editing the code trough CKeditor.
I see the br and remove this then save it again, and the double enter is back.
I cannot find the sollution, i tried to adjust the config.js
Butt no result
Also when i add a image and adjust the format and then save, he putts the image back to his original format.
I hope someone can help me, i have been looking for weeks to get it right.
Thank you
With kind regards
Twindaddy
This is the tekst
This is the tekst
This is the tekst
This is the tekst
He saves it as:
This is the tekst
This is the tekst
This is the tekst
This is the tekst
Butt no result
Thank you
With kind regards
Twindaddy
Re: Double Enter Problems
http://dev.ckeditor.com/ticket/8581
when i add the following line my Editor stop working
writer.lineBreakChars = '';
when i remove it my editor comes back butt still the same problem
With kind regards
Twindaddy
