CK doesn't really care about the server-side scripting that's used; Technically, it could be used on a plain HTML page. Some plug-ins or features (e.g. CKFinder) will need you to code something yourself if there isn't a handler already coded for you (I think there's no ASP file handler in CKFinder for example, but I could be mistaken).
keilaron wrote:CK doesn't really care about the server-side scripting that's used; Technically, it could be used on a plain HTML page. Some plug-ins or features (e.g. CKFinder) will need you to code something yourself if there isn't a handler already coded for you (I think there's no ASP file handler in CKFinder for example, but I could be mistaken).
If you look at the CKFinder site you'll see that it has versions for classic Asp, Asp.Net, ColdFusion and PHP.
Re: Does CKEditor work with classic ASP?
