can someone please tell me, if CKEditor work with ASP.Net or I need to use the old FCKeditor?
And if it works how to install it. Because, the instructions in the site is kinda vague.
Regards
Regards
Re: Does CKEditor work with ASP.NET?
Checkout \ckeditor\_samples\replacebycode.html you should be able to get started from there
Hi! I have made an ASP.NET control that works pretty much the same as FCKEditor control did.
Take a look at: viewtopic.php?f=11&t=15882
Just take the DLL from the file, put it in your BIN file, and register it on your page or in your web.config
