Hi all.
I have several div styles setted on my ckeditor custom.js in order to have my div container list populated.
This also mean I have several useless lines in my style box, but I can survive with this, since I saw no answer when this was asked on other topics.
I can happily select several blocks and apply a div container, even if I cannot avoid to have it with undefined style... I mean I already have styled the div from its class, why would I apply another style here??? (my styles are all with class attributes, not with style applyed)
Main problem is I can only remove those div from the source view (but this goes for anchors too), and I can't change the class of a selected div.
If I select an image and click on the image icon again, the right info are selected on the popup windows. Same for links.... but if I select a div and div container, all I can do is adding a nested div outside the existing one... class and style of existing one is not showing!
I don't like wysiwyg editing, but the students at university that uses that editor are not really good at coding html... it would be useful to edit those div once entered...
About removing... well, if you could find a way to make a div that is not nested once you setted the first one... that would be great too! I love the block view
I suspect this is a task a bit too specific for this editor... but I thought it had no sense to give a div container and than have it not really working...
