In my config.js, I have this:
in the editor, when I type
I get
the only characters that should be escaped are the basicEntities (which defaults to true)
and then, when I define those four things inline on a different editor like so
when I do
the & is still converted. So.. I'm pretty sure these settings have no effect on the editor....
is this a bug? am I doing something wrong? I'll work on a jsfiddle to try to replicate in a controlled env.
config.entities = false; config.entities_greek = false; config.entities_latin = false; config.htmlEncodeOutput = false;
E’s'#he &
I get
E’s'#he &
basicEntities: false, entities: false, entities_greek: false, entities_latin: false, htmlEncodeOutput: false,
when I do
yourEditor.getData() "E’s'#he &"
