In PasteFromWord plugin, the images will point to the local file system and hence found to be broken in the editor content. So we solved that issue by uploading the images in the content to our server and replace the img src with corresponding server refId of the image.
This feature has a dialog which shows the summary of files uploaded to server and hence applet is loaded over the dialog.
On pasting the content, we found the dialog loading then suddenly the entire page alignment gets collapsed.
While investigating regarding this issue, we narrowed down that in "dialog" plugin, auto-focus logic of dialog (binded to dialog onShow event) only breaks the entire page alignment.
Any clue/fix for this issue?
Note : We found that increasing the timeout time of "Rearrange the dialog to the middle of the window" function (actually show event is fired inside this function only) is the temporary fix. Initially it was 100 millsec and we raised upto 600 millsec. But we cant rely on this fix since the bug still arises occasionally.
Re: Dialog auto-focus breaks the entire page alignment!
1. Copy the content from ms-word with pictures included in it.
2. Paste the content in the ckeditor using ctrl-v.
actual :
Images corresponding to picture in word are found to be broken since the src of img pointing to clipboard image path.
expected :
Image should be rendered properly and hence those images should be uploaded to server and src of img tag should be replaced by server image url.
So I developed an applet which uploads the image and replace the src with uploaded server url. I load that applet in a dialog and show the user, the list of images uploaded or image uploading failure. But if the dialog loads, the entire page is found to unaligned frequently.
Note : This happens only in case of IE and working fine in non-IE browsers.
I'll pass. Maybe someone else wants to create all that setup, but I don't have the time.
I'd really love to be able to paste from word with the images included.
