I have editors on multiple pages on my site, many with different settings, such as toolbars. What I was hoping to do is have all my common settings in one configuration file and then have settings for each type of editor stored in individual config files. I don't want to specify setting in-page, since several instances will have exactly the same settings.
I tried putting multiple toolbar definitions in the global config.js:
Then I have a custom config file called instance1.js which looks like:
Then in my page, I do this:
When I do this, I get the error:
"u is undefined" at line 66 of ckeditor.js
If I remove the following from instance1.js the error goes away:
It seems that as soon as I specify a custom config in-page, the settings in the global config.js are completely ignored, instead of cascaded.
I also tried putting all of the toolbar settings in baseConfig.js and changing my instance1.js to:
It seems like this just completely ignores the second line where I set the toolbar.
Can someone tell me what I am missing here? Or is there no way to actually cascade settings, and I need to duplicate all my common settings in all of my custom config files? Thanks.
config.toolbar_Bar1 = [ [ 'Cut'] ];
config.toolbar_Bar2 = [ [ 'Copy'] ];
config.toolbar_Bar3 = [ [ 'Paste'] ];
config.toolbar = 'Bar1';
CKEDITOR.replace( 'EditorArea',
customConfig : 'instance1.js'
config.customConfig = "baseConfig.js";
Re: Cascading customConfig settings
I had a similar issue, returning the same "u is undefined" error.
After running some test I found out this error gets thrown when you specify a config.toolbar name and then the corresponding toolbar array doesn't exist.
in your case calling config.toolbar = 'Bar1'; while config.toolbar_Bar1 is not there.
I've also found out that the config.js in the base dir doesn't get loaded automatically.
the ting that should work for you is:
file: instance1.js
CKEDITOR.editorConfig = function( config ) { config.toolbar_Bar1 = [ [ 'Cut'] ]; config.toolbar = 'Bar1'; };file: yourpage.html
CKEDITOR.replace( 'EditorArea', { customConfig : 'instance1.js' });make sure the path here is correct.
hope this helps,
Tedge
CKEDITOR.replace( 'EditorArea', { customConfig : 'instance1.js' });CKEDITOR.editorConfig = function( config ) { config.toolbar = 'Bar1'; config.customConfig = 'common.js'; };CKEDITOR.editorConfig = function( config ) { config.toolbar_Bar1 = [ [ 'Cut'] ]; config.toolbar_Bar2 = [ [ 'Copy'] ]; config.toolbar_Bar3 = [ [ 'Paste'] ]; };
