I am using CKEditor 3.3. I want to monitor the clicks that happens on texteditor control. Now for trial purpose i am modifying the enterKeysample provided with the installation. Below is the code i put in the existing changeEnter funtion.
var element = CKEDITOR.document.getById('editor1');
element.on( 'click', function( ev )
alert('clicked here');
i have added reference to the javascript file using statement
<script type="text/javascript" src="../ckeditor/_source/core/dom/event.js"></script>
Although its not capturing the click event after loading of complete page. can anyone suggest me, what has gone wrong?
Thanks in Advance!
Thanks in Advance!
Re: Capture click event on text editor control
OK. I am trying my own test page to integrate the CKEditor insted of modifying any sample. Below is the very simple html souce.. Can you please let me knw why click is not working for me? Please suggest if you have different idea.
<html>
<head>
<title>Sample - CKEditor</title>
<script type="text/javascript" src="/ckeditor/ckeditor.js"></script>
</head>
<body>
<form method="post">
<p>
My Editor:<br />
<textarea name="editor1"><p>Initial value.</p></textarea>
CKEDITOR.replace( 'editor1' );
</p>
<p>
<input type="submit" />
</p>
</form>
</body>
</html>
Thanks in advance
<script type="text/javascript" src="/ckeditor/ckeditor_source.js"></script>
Since you changed the source files, you either need to recompile ckeditor.js or use the source version
