In case anyone here has a similar problem, here are my posts from the ckeditor drupal module issue where I figured out I was a dummy:
techcord - January 19, 2010 - 09:17 A little more data: the '../userfiles' section of the bogus URL is definitely coming from the 'file system path' setting in site configuration > file system in drupal. When I change what's there, it changes in the ckeditor dialogs. I still have no idea where the '/fcsweb/sites/all/' section is coming from, or why it's trying to use the 'file system path' setting when there's a perfectly good setting for file uploads in the ckeditor module. I think it's safe to say that the ckeditor module is involved in this somehow. Any thoughts on where I should look? Again, thanks for the great work y'all have done on this already!
techcord - January 19, 2010 - 09:35 Status: active » closed I am a colossal idiot. It turns out that setting is in filemanager.config.php in the includes directory of the ckeditor module. There are variables helpfully named $ckfinder_user_files_path and $ckfinder_user_files_absolute_path. It helps if you set them. If they're not set, the authenticate function tries to set them, and in my case (which is non-standard), didn't do it right. So, there ya go. Amazing what a good night of sleep will do you.
Re: CKeditor + CKfinder + Drupal (CKeditor Module) url problem
A little more data:
