Hi guys,
I'm having problems getting CKEditor to display on my page. The textarea it's supposed to be replacing is getting its visibility correctly set to hidden, however no new element is created for the CKEditor. So I've been trying to get to the bottom of this, and decided to mess around with the sample files locally.
I was debugging using the jqueryadapter.html sample file.
I changed the source of the javascript files necessary to the copies held in my website's directory. So..
This resulted in the same problem occuring i.e. CKEditor not showing. However, if I changed the location of 'ckeditor.js' to the copy held in the ckeditor directory, it would work.
I have no idea what conclusion to form from the above.
Can anyone please enlighten?
Thanks!
<script type="text/javascript" src="../../../code/js/jquery-1.4.2.min.js"></script> <script type="text/javascript" src="../../../code/js/ckeditor.js"></script> <script type="text/javascript" src="../../../code/js/jquery.js"></script>
<script type="text/javascript" src="../../../code/js/jquery-1.4.2.min.js"></script> <script type="text/javascript" src="../ckeditor.js"></script> <script type="text/javascript" src="../../../code/js/jquery.js"></script>
Thanks!
Re: CKEditor not displaying
