I'm using Joomla 2.5.8 with the latest CKEditor for Joomla and I cannot get the styleSet to work. Any help here would be appreciated. I have tried not using the template style sheet to avoid conflicting CSS file names*. The file matches the css file name which I copied from the template to the correct location... I'm stumped. Has anyone else had a similar problem?
I've included the file which is really the example file with everything commented out except one style I am trying to add. The associated css file is being used because I can see it in the editor (styles in the WYSIWYG window match the css file).
When I use the default styleSet version it works. When I use this file, I see no styles in the drop down at all.
*I mention conflicting css filenames because I tried this with the radio button on both use and don't use the Joomla template css, but the radio button setting (incorrectly) uses the admin template rather than the front end template, so when it is set to "use" the template css, there are two css files named "template.css" though only one is in the correct location for the styleSet and in either case it failed every time.
