The original issue was logged over 9 months ago. I see that there is some kind of patch logged in the issue. Does that mean that the issue has been resolved?
As far as I can see, the patch doesn't solve the problem. If anyone has an idea on how to solve this, it would allow me to use CKEditor in a responsive layout, which can't be done at the moment.
Hi Anna, as a matter of fact, I need to apologize. I tried again and the patch does indeed fix that bug. Thanks for pointing me in the right direction, it all works fine now! Good luck with V4
Re: CKEditor does not resize in WEBKIT
yes it is! It's exactly the same behavior.
Has there been any fixes or workarounds for this?
Thanks!
http://dev.ckeditor.com/wiki/TicketLifeCycle
