So I'm using CKeditor inside of a jQueryUI dialog. The issue I'm having is when you click on a button like the "link" button, the modal that pops up, won't let me type anything into it's inputs. I can change the values of the pull downs, I can drag the modal around the screen, and I can click on the buttons. But when I attempt to type into the text inputs, nothing happens. Has anyone else come across this? If so, did they find a solution? Thanks!
Fri, 03/19/2010 - 01:29
Re: CKEditor Modal Issues
http://dev.jqueryui.com/ticket/4309
