Hey guys, I've searched the forum to see if I could resolve this issue but I've not found the issue. The editor just is not appearing correctly in IE8, however it looks BEAUTIFUL in FireFox. I downloaded the newest 3.0.1 and hoped that would fix it, however it's doing the EXACT same thing.
If you look, you'll see how the main body of the editor is moving outside, like it's floating incorrectly. This also makes it difficult for anyone in IE8 to click on the body of the editor and start typing. And I know, most people don't like IE however it gets used and I'd like to be as compatible with everyone as I possible can.
Is their a solution for it, that anyone knows about, or is it being worked on?
This problem has happened on numerous computers, I have checked to ensure it's not just one computer with a weird configuration. I also have not done anything to any CSS related to the editor and as far as I know nothing in MY CSS should be effecting it, wince it works PERFECT in FireFox 3.x
Thanks for all the help!
Re: CKEditor Issue in IE8
It's a weird issue, and I'd like to figure it out and since the Demo isn't doing it, either they have something else set up or something I've done has caused it (which I've not mucked around with the editor other then doing custom tool bars). What gets me and makes me think it's not my CSS is that it works PERFECT in FireFox.
Thanks in advance for any help!
It is my CSS definition for the fieldset tag, I have it moved in 3% from the left. Using the developer tools, I unchecked that styling and POOF...all fixed.
Thanks again! That totally solved my problem!
